105 combine
farmer boy
01-02-2002 16:35:20
I HAVE THE CHANCE TO BUY A 105 JOHN DEERE COMBINE . IT HAS A 4 ROW NARROW ROW CORN HEAD AND A 13 FOOT WHEAT HEAD ALL IN GOOD SHAPE. THE COMBINE IS NOT A CORN SPECIAL. IT IS ONE OF THE FIRST ONES I THINK BECAUSE IT DOSE NOT HAVE AC.IT HAS ABOUT 1 AND A HALF FOOT HOPPER EXTION. THE COMBINE HAS DOBLE SPINNERS ON THE BACK TO SPREAD THE CHAFF. THE PAINT IS GOOD AND SO IS THE SHEAT METAL. THE COMBINE HAS SAT INSIDE SICE IT WAS NEW. WHAT WOULD BE A GOOD PRICE FOR THIS COMBINE AND HEADS. I DO NOT KNOW IF THIS IS RARE BUT IT HAS A ROATING FAN FAN LIKE ONES THE 40 FOR A AIR CLEANER THE FAN MOVES WHEN THE AIR GOSE IN TO IT THIS IS FACTORY..THANKS IN ADVANCE GUYS!
FARMER BOY
doble spinners?
01-08-2002 06:34:10
 Re: 105 combine in reply to farmer boy, 01-02-2002 16:35:20
the "doble spinners" on the back are known as straw spreaders.
Lyndon
01-05-2002 19:52:59
Good luck with your combines! I have two 95R rice machines(one with tracks)and just recently purchased a 105R. I plan to restore them in the future and play with them in our Louisiana rice fields.
john2510-3020
01-03-2002 18:27:58
WOW farmer boy! for 13 you have been around the blocka time or two! sounds lie you have alot ahead of you hope the series deal works out for you. i know where a 95 is with a 16' head and 4row narrow corn head is the motor does not run...tried to get it to run but wouldnt(rebuilt carb and that was about it) sitting i woods now....has wooden bats on reel has cab and a/c i think not sure though....uncle has it will see if he'll let go of it. talk to you later...oh yeah drop me aline or posat back if interested also.
john
Steve J
01-02-2002 16:59:10
If you could post the serial number I can tell you what year it is. It sounds like a normal 105,many didn't have ac. The price range on good ones around here(central IL) are from $1000-$2500. The diesels bring more because the engines will fit in a 4020. A qick-tach is better for newer heads but can be added. If its the 435 head,its not worth much,and replacement parts are hard to find. It sounds like a good one. Good ones are hard to find,when new,they were used on bigger acreage and many were wore out before now. When I bought mine,I offered what I thought it was worth. The guy wanted more but he wanted to give it a good home. Good luck, Steve
farmer boy
01-02-2002 17:06:09
 Re: Re: 105 combine in reply to Steve J, 01-02-2002 16:59:10
i do not have the serial number,it is a gas.
farmer boy
Steve J
01-02-2002 17:15:47
 Re: Re: Re: 105 combine in reply to farmer boy, 01-02-2002 17:06:09
Its Probibly 1966 or newer. Just guessing. Most early ones are gone. It would probibly be a good one to hobby farm with.
farmer boy
01-03-2002 15:20:03
 Re: Re: Re: Re: 105 combine in reply to Steve J, 01-02-2002 17:15:47
THE REASON WY I WANT TO BY THIS COMBINE IS I AM COLLECTING THE WHOLE SET OF THAR SERIES OF COMBINES[40,45,55,95,105]. I HAVE THE 40 WITH BOTH HEADS AND RUNNING, AND THE 55 WITH BOTH HEADS AND RUNNING. AND I HAVE A 45 COMBINE LOCATED WITH BOTH HEADS AND RUNNING. ALL I NEED ARE THE 95 AND POSSIBLY THE 45. IS THE ROATERY FAN ON THE 105 VERY RARE.
FARMER BOY
Swenny
09-16-2003 15:23:13
 Re: Re: Re: Re: Re: 105 combine in reply to farmer boy, 01-03-2002 15:20:03
Please post pictures of your collection. I would love to see them.
cb
01-04-2002 12:51:32
If you can haul them I see 105's show up
on www.machinefinder.com
most of the 105 are in
the northern plain states and canada that I see.
Dave
01-04-2002 06:16:35
The rotary screen was an add on and did not come standard on those models. I have a 105 diesel, hydro but it did not have the quick tach throat. This fall at an auction I bought a 105 corn special with QT throat and real nice 444 wide corn head. It was always shedded, gas and belt drive and I drove it home. I paid $1300 for the whole works and now I can use the modern heads and have the rest for parts.
Seven-Sixty
01-03-2002 15:54:00
I really commend you for attempting to obtain a whole family of the John Deere combines. If you have the time and money, you may want to go as far as collecting them by sub-groups, such as high-bin, Hi-Lo, and square back. It would really be great to see even the PT or hillside companions to the models, such as the 42, 65, 55H, 95Hand 106.
Steve J
01-03-2002 17:25:08
 Re: Re: Re: Re: Re: Re: 105 combine in reply to Seven-Sixty, 01-03-2002 15:54:00
If its got a rotating screen,it must be something someone has added. It wasn't an option when new. Thats great if you can get all the sizes. I thought about it but I don't have enough room to store them. My 55 and 105 take all the room I have. If I could get a bigger shed I'd do the same. That 40 is the rare one.
farmer boy
01-03-2002 18:11:56
 Re: Re: Re: Re: Re: Re: Re: 105 combine in reply to Steve J, 01-03-2002 17:25:08
The 40 could probley fit between youR 105 and 55. The 40 was only 16 foot 8 inChes long and 7foot 5inches wide with no header on the combine was also 8 foot five inches hie. the 40 only had a 8 or 10 foot wheat head and a 205 2 row corn head. the hopper could only hold 32 bushels. The horse power was 42 horses. the 40 had no power steering or the ladder to the motor over the gas tank. i know a man whose has the whole set of pull type combines but he dose not want his name reveled because he dose not like to talk.i am lucky that i have a big shed it is 160'x60' with power and a cement floor and power.I also have a 144'x40 with cement and electricy and alot more dirt floor implement sheds. i am only 13 and this is all that i have.
JD 620 TRACTOR
JD 40 COMBINE NO CAB
JD 55 COMBINE CAB
JD 205 CORN HEAD
JD 313 3 ROW CORN HEAD
JD 8 FOOT WHEAT HEAD
JD 13 FOOT WHEAT HEAD
JD 494 PLANTER
JD EE STEEL WHEEL DRILL
JD 4 ROW CROP CULT 3PT
JD 4 ROW FROUNT MOUNTED CROP CULTIVATOR
JD 2 ROW GO DEVIL
JD 1-B CRANK CORN SHELLER JD 234 2 ROW CORN HEAD
JD 227 PICKER
JD TUMBLE BUG
JD NO-4 BIG HORSE DRAWN MOWER
JD 1 BOTTOM HORSE DRAWN PLOW
JD 999 2 ROW CHECK ROW PLANTER
JD 24 FOOT HAY ELVATOR
CASE 2 BOTTOM BREAK AWAY PLOW
CASE F 7 FOOT BAR MOWER
CASE PR 1 ROW PICKER WITH HUSKING BED
AC ROTO BALER ORANGE TOP
AC 66 ALL CROP COMBINE
MC CORMIC HORSE DRAWN PLANTER 2 ROW CHECK ROW
MC HORSE DRAWN DISK
MC 1 ROW DISK CULTIVATOR HORSE DRAWN
CHAMPION 1 ROW CROP CULTIVATOR HORSE DRAWN
RUSSEL JR HORSE DRAWN ROAD GRADER
WETMORE HAMMER MILL
ARMSTRONG CARSON BLUE GRASS STRIPPER
KNIEB BAlE LOADER
AMERICAN STEEL WHEEL DRILL WOOD BOX [PARTS]
JD HORSE DRAWN RUNNING GEAR
MC INGATE SEEDER FOR FLAIR BOX WAGEN
BURKENS FLAIR BOX WAGEN
CLIPPER SEED CLEANER CLIPPER SEED CLEANER BIGGER
HIG-BEE OATS CLEANER
PATCHES PATENT BOX CORN SHELLER
12 AND A 36 INCH HAND SYE
OLIVER FLAT BOX HAY WAGEN
W 3PT SEED SPREADER THAT IS ABOUT IT,IN ALL IT HAS COST ME $4683. MY DAD COLLECTS HIS OWN LINE OF EQUIPMENT TO THE JOHN DEERE 3010 OF HIS. WE BOTH RESTORE EACH OTHERS MACHINERY AS SOON AS WE GET IT HOME.IF YOU HAVE ANY ? ABOUT THIS EQUIPMENT JUST EMAIL ME OR POST A FOREUM. FARMER BOY
Steve J
01-03-2002 19:01:59
 Re: Re: Re: Re: Re: Re: Re: Re: 105 combine in reply to farmer boy, 01-03-2002 18:11:56
Looks like you have a museum already. You could open up for viewing someday. I could probibly get a 40 and 45 in my other shed. I had to build a newone to get the 55 and 105 in. I have other hobbys taking up room also. My collection consists of-
105 diesel combine
55 combine
4400 diesel combine
343 corn head
15 ft platform
13 ft platform
Woods Brothers 1 row picker-with wagon
292 check planter
7000 planter
1971 4020 diesel
1950 A John Deere
1952 8N Ford with many attachments
no.5 sickle mower
6' bushhog
Deere hay wagon
18 1/2' AC field cultivator
10' Kewanee disk
RG630 cultivator
555 Deere 3-14 plow
Oliver 4-16 plow
2 row front culivator(for the A)
5 horse drawn plows
JD Sportfire snowmobile
JD spitfire snowmobile
5 AC garden tractors 2 Simplicity garden tractors
582 stock-altered Cub Cadet puller
582 superstock Cub Cadet puller
1956 ford pickup
Most of this I use to farm with. Some I don't use. I bought a 2001 F-250 Powerstroke last year so my buying has been limited. I'm trying to sell the 4400 and 343 head. I need a 643 for the 105. Steve
farmer boy
01-04-2002 14:04:35
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 105 combine in reply to Steve J, 01-03-2002 19:01:59
Man Steve you sure do have alot of equipment that i would like to have.Well see you later.
Farmer Boy
Tim(nj)
01-03-2002 19:35:52
What year 4400 and what shape is it in? I know a guy in Pennsylvania who's always on the lookout for good smaller combines like 4400 Deeres (and 343 heads) and Gleaner K2, F2 and F3s. He hauls stuff in from everyplace east of the Mississippi. If you have trouble selling it where you are, let me know, I'll get you in contact with him if you want.
