John Deere 1240 Planter
Adam Schuh
11-22-2005 17:30:49
I just bought a JD 1240 Plateless planter. I tried it out today in the driveway and only two rows drop corn. I opened up the seed chute down to the finger pickup and it was full of seed. Some of the seed in the bottom seemed to be a little molded though. Any ideas, thanks
Tim in Western PA
11-23-2005 10:44:32
 Re: John Deere 1240 Planter in reply to Adam Schuh, 11-22-2005 17:30:49
Pull the access cover off of the side of the planter units. The big cover that goes over the finger unit. The finger unit is most likely gummed up from sitting and the graphite lubricant. I've had one for a few years and clean each one out before starting planting. pull the chain off and you'll be able to turn the finger units by hand.
Tim in Western PA
11-23-2005 10:41:50
Adam Schuh
11-23-2005 17:09:47
 Re: John Deere 1240 Planter in reply to Tim in Western PA, 11-23-2005 10:41:50
I'll try cleaning it all out. After it's cleaned should I lubricate it or just let it dry until spring?
OH Boy
11-23-2005 09:46:07
Sounds like it is plugged up with mud at the bottom.
Greasey Hand
12-04-2005 12:54:00
 Re: John Deere 1240 Planter in reply to OH Boy, 11-23-2005 09:46:07
Check for a broken roll pin in the drive meck.
These brake when the fingers get caught on the ss wear strip. the ss strip should be changed to.
Greasey Hand
12-04-2005 12:49:56
