Harrow bearings
53GoldenJubilee
12-13-2005 15:44:59
Hi all, I'm looking at some old 3pth mounted disc harrows at the local equip. store, a few of the harrow frames look pretty good but, i think they may need bearings. Any idea how much it cost to get a set of bearings for a tandem gang setup for something about 6ft wide?
Thanks in advance for the help!
Bernie in MA
12-16-2005 09:02:18
 Re: Harrow bearings in reply to 53GoldenJubilee, 12-13-2005 15:44:59
baileynet.com has bearings
paul
12-13-2005 21:37:52
Now there's a loaded question! :)
Some will be regular cheap ball bearings. Some will be a $115 Timpkin - type set - each.
Some will be wood that you can carve yourself if you can find a hunk of good hard wood.
Some will be cast metal deals, about impossible to find, tho some old metal workers can repour them - if they aren't damaged all to heck.
Then, depends how long it was run while already shot. What else was damaged, the bearing holder, the frame, the rod?
Real hard to give any meaningful answer.
--->Paul
