3-point scoop which is the best built and size?
larry o
01-09-2000 13:33:58
I have noticed there are different types of 3-point scoops. Some scoop frames are made of angle and other frames are made of round stock. Which is stronger? There seems to be two sizes, 30" and 36". Is that the outside dimension of the frame, or the with of the scoop? Are all brands about equal, or is there one brand that is significantly better than the rest? Thanks for any input.
Bill OH
01-20-2000 05:17:50
 Re: 3-point scoop which is the best built and size? in reply to larry o, 01-09-2000 13:33:58
I got a Ford scoop at an auction years ago that has worked very well on my '41 9N. I think it was made in the late '60s or '70s. It has a large tube frame.
John (NL)
01-10-2000 08:10:23
For what it's worth, over on the Ford N Board they had a string on second hand Dearborn Scoops a week or so ago. The consensus was that the old Dearborn scoops you can get at farm auctions were better than the ones you can buy new (if in good condition). Whatever you do, make sure what you buy is reversable.
John
Gerald J.
01-11-2000 12:28:23
 Re: Re: 3-point scoop which is the best built and size? in reply to John (NL), 01-10-2000 08:10:23
Reversible? That leaves out my Dearborn trip scoop!
Gerald J.
Burrhead
01-09-2000 15:59:53
Larry I don't know which is best, but these Howse and International Mfg I have here aint worth a hoot.
They measure these at the outside of the bucket. The best I've seen around here are Modern Mfg-Beaumont,Tx. I don't know if there available where you are.
larry o
01-09-2000 19:17:54
 Re: Re: 3-point scoop which is the best built and size? in reply to Burrhead, 01-09-2000 15:59:53
Thanks for the info. I was going to call International Mfg tomorrow morning. You saved me a quarter and a 120 mile round trip. The round stock steel frame looks stronger, but I'm no engineer. Monday I will call CT Farm and Country and Big Blue. Thanks for the calendar. The "Big Bud" tractor (in the calendar) is a man's man machine.
Burrhead
01-10-2000 14:09:57
 Re: Re: Re: 3-point scoop which is the best built and size? in reply to larry o, 01-09-2000 19:17:54
Ma Burr thought you'd like it, and I'm glad you do. A farm house just aint right without something like that in it.
You're welcome and good luck.
