How to dig trenches
MikeH(Tx)
01-10-2000 06:44:41
Is there a plow-like attachment that would fit on a tool bar and dig a decent trench for PVC pipe? I have been laying some drip irrigation line and using a regular middlebuster plow to dig the trenches. It works, but makes a much too wide hole. I'm not sure anything would make a pretty trench like a dedicated trencher, but it seems to me a better shaped plowshare would get me halfway.
I am in Central Texas, so freezing is not a problem as long as I get it completely underground.
ted
01-21-2000 11:46:55
 Re: how to dig trenches in reply to MikeH(Tx), 01-10-2000 06:44:41
Get ahold of a twisted chisel point. I think they are around 2 1/2 - 3 inches wide. They are used on Soilsaver chisels. If the bolt pattern will match up you will be set.
It doesn't have to bolt on the best, just get it on and halfway tightened.
In grass, at least, you will just have to clean the trench out a little with a pick. I don't think it will work in loose ground inless you can put the pipe in directly behind the point.
Jim Waits
01-14-2000 21:08:27
I am a novice at this. Just got my first tractor, a 25hp New Holland 4wd. Been wondering about how to do this same thing. After reading these posts I looked at my middle buster and am wondering.....
I could take my cutting torch and reduce the size of the middle buster without changing the length. Maybe find an old worn out middle buster blade and use it to avoid ruining the new blade on my setup.
This would still dig deep and still throw dirt away to the sides but would not be too wide. Any comments on this?
JamesJ(TX)
01-10-2000 08:06:37
Mike, check out the website for Tractor Supply, they have a 3 pt. subsoiler listed that might work for what you want.
Burrhead
01-10-2000 14:17:45
 Re: Re: how to dig trenches in reply to JamesJ(TX), 01-10-2000 08:06:37
If your middlebuster is like mine. You can take the shovel off of it and put a flat or needle cultivator on it and it does pretty good for digging pipe ditches. That's what I did with mine to make it easier to back fill the ditch. This makes a ditch about 4" wide that you can backfill with a blade or boxblade real easy.
I like anything that keeps me off of a shovel handle. I buried about 675' of 3/4" pvc about 1' deep to the pasture with mine, and it did good.
Taylor Lambert
01-29-2000 14:13:19
 Re: Re: Re: how to dig trenches in reply to Burrhead, 01-10-2000 14:17:45
You can take a sub soiler and weld a peice of pipe on the back of it to lay pvc pipe that comes in a roll. I built one like this for my Cub and for a Jubilee ust unroll the pipe and let it feed up ver the fron axle, you can even ad a reversed v to back fill in the same swipe. I built another one this summer to go on the front of a D5B cat dozer bladeworked real good laying 1 1/2 gas lines.
MikeH(Tx)
01-10-2000 14:58:28
Thanks to both for the idea. My middlebuster, from Central Tractor has both a plow and an interchangeable "ripper" which is what I presume you are describing. It worked really well for digging a trench, but did not throw the dirt out. I ended up putting the plow back on and using that. The plow threw the dirt out ok, but left a foot wide V shaped trench.
I was wondering if there was a sweep or chisle or plow I could add that would split the difference - dig like the chisle and throw dirt like the plow.
For the next trench, I used my cultivator. I removed all the bars except two, which I put one behind the other. This worked about like the ripper, dug ok, but didn't throw the dirt worth a hoot. Since the sweeps are replaceable on a cultivator, this got me thinking about putting on one that would do better for trenching. (Using the cultivator also allowed me to move the sweeps over all the way to one side so that I could dig a trench closer to obstacles. The plow idea was middle of the tractor only, thus three feet away from any obstacles.)
Somebody has got to have this problem solved already.
Use your Kid: Kim Hartshorn
01-11-2000 09:48:47
 Re: Re: Re: Re: how to dig trenches in reply to MikeH(Tx), 01-10-2000 14:58:28
I was told by a guy at the supply store that he used a middlebuster plow....but had his kid following the tractor with the roll of pipe feeding the pipe right into the seam immediately behind the plow...they never moved any dirt at all. I have not done this yet but intend to in the spring. The trench implement from cadplans seems to work the same way except they use a subsoiler blade instead of a plow and a curved pipe to lay the black pipe in the bottom of the trench. I went to the autosupply and bought a piece of curved tailpipe to strap on the back of the subsoiler tool bar. I made a homemade tool bar this fall and tested the rig it looked like it was going to work but my homemade job did not pass the test of real life and twisted up pretty good. Now the trencher is a winter project waiting for spring :-)
Good Luck
Kim
Burrhead
01-11-2000 11:17:00
 Re: Re: Re: Re: Re: how to dig trenches in reply to Use your Kid: Kim Hartshorn, 01-11-2000 09:48:47
I watched the folks put some phone cables underground here yesterday. I think it would work on a middle buster like you're saying. The one guy just started the cable through the pipe on the trencher and when it started pulling itself through there he just stepped back and let it go. I don't see why it would'nt work on a plow, it's the same principle.
