Well, I'll help where I can: The original belt looks quite worn. How do I connect the metal loops on the end of the belts. I was told to use a rawhide dowel. Is this correct? Yes, a rawhide dowel is the way to go. Were can I get this connector? Were can I get a new section of belt? I dunno, but a web search should bring some intereting results. If I want to cut the longer belt, is there any trick to installing the metal eyes on the ends? Yes. There's a tool that fits in a vice. You buy the "lacing" in bulk, cut it to length, set the open lacing in the tool, put the cut end of the belt in between the teeth of the lacing, and tighten the vice, which closes the die and drives the ends through the belt and crimps them. The set of laces that go on the other end of the belt are offset slightly so they mesh properly and the edges of the belt line up. What should I use for a belt dressing? Not real sure on this, but there should be a spray can type dressing available. You MIGHT be able to use the stuff NAPA sells for noisy fan belts, but I'd get a second opinion on that.
