New Holland Round Baler Question
Allan in NE
01-18-2006 16:42:11
Hey Guys,
Does New Holland make replacement sheet metal panels for the high wear areas in the chamber like combine manufacturers do for their combines?
I've got one spot that is about 3" long by 1/4" wide coming thru the right side by the forming cam. I wanna stop it before it gets any worse.
Thanks,
Allan
RickL
01-18-2006 18:54:09
 Re: New Holland Round Baler Question in reply to Allan in NE, 01-18-2006 16:42:11
You want me to find out as I help dealer who handles New Holland all time,could fined out tomorrow idf you want.
Gary in TX
01-18-2006 17:02:27
Hey Allan,
I don't know either but I've got the same type deal going on on my 530 Deere on the right hand side on the back edge of the main bale chamber, Mine is much larger than yours though. I'm thining of using a say 1/8 thick piece of angle iron and lapping over it or using my wire welder and building it up by sliding a piec of thin steel in the slot and welding around it. Keep me in mind if you run across any different ideas.
edchainsaw
01-21-2006 19:15:27
 Re: New Holland Round Baler Question in reply to Gary in TX, 01-18-2006 17:02:27
my 852 just started showing a wear out spot on its right side last field I baled... so I was thinking JB WELD?
Allan in NE
01-18-2006 17:41:43
Hi Ya Gary,
If I can't get replacement panels, I'm going to go to the Lenox heat and air conditioning place here and just buy some stock galvanized ducting material and pop rivet it in place right over the top of the original skin and leaving that original panel in in the machine.
It is kinda like roofing flashing from the lumber yard only a little thicker stock, I think. I've done this on combines in various locations and it gives 'em a whole new life and is totally unobtrusive as far as the machine's operation goes.
Thanks,
Allan
504
01-18-2006 18:06:53
 Re: New Holland Round Baler Question in reply to Allan in NE, 01-18-2006 17:41:43
One of the local hardware stores used to make patch panels for augers from galv. They kept them in stock for augers on JD combines(45-55 etc)
