pull type mower
mpuller2
01-31-2006 09:01:38
Who makes a pull type PTO mower? I need something to pull behind a M Farmall to cut an acre of grass. I don't want the tractor to be tied up with a mounted mower. Thanks
blocks
02-05-2006 19:49:50
 Re: pull type mower in reply to mpuller2, 01-31-2006 09:01:38
I got an old three point bush hog from a farmer friend of mine that needed a gear replaced. I took two 1/2 X 2 steel bars and welded them to the braces on the mower removed the three point linkegs driled two holes to match up with the out side holes on my M's drawbar. I don't have any way to raise it but with the rear wheel. I mow about 15 acres been doing it for two years now . I put an over run on the PTO.6 foot does't even make it work even in the tallest weeds.good luck Dennis in MI
Don L C
02-01-2006 20:05:00
I saw a good looking pull type IH mower on " PHOTO ADS " yesterday..... use the search box it should take yoy to it..... .Don
souNdguy
02-01-2006 18:46:23
How big a mower will that M pull? 6-7-8?
Might try looking at howse / kk. I know howse makes some nice 10' pull types.
Soundguy
cj3b_jeep
02-01-2006 13:40:33
I used to have a 5 foot Bush Hog pull behind that I towed behind my Jeep. The jeep has a PTO, but not live. I worked, but not well. The cutting aspect was fine, but to turn required a little finesse with the clutch and so. Because of it being a trailer type, the shaft wanted to bind when you turn.
See:
Link
For some images of this.
I'd go with the belly mower or even one of those swisher trail mowers if you can find a good deal on one.
cj3b_jeep
02-01-2006 13:35:32
See:
Link
RustyFarmall
01-31-2006 13:24:28
third party image
Something like this? This is an IH #31. similar units were made by New Idea, Allis-chalmers, john Deere, and countless others.
mpuller2
01-31-2006 13:33:08
 Re: pull type mower in reply to RustyFarmall, 01-31-2006 13:24:28
No, I don't want a sickle mower, too dangerous in town. Hopefully something to pull behind without having a 3 point hitch. Is there anything made to hook to the drawbar (pin hitch) and is PTO driven?
RustyFarmall
01-31-2006 18:00:29
 Re: pull type mower in reply to mpuller2, 01-31-2006 13:33:08
third party image
How about a belly mower?
ejr-IA.
01-31-2006 13:06:36
New Idea,IH,New holland many of the majors.Run a add in the classifieds.
Tim(nj)
01-31-2006 12:09:30
 What kind of mower? in reply to mpuller2, 01-31-2006 09:01:38
Sickle bar? Drum? Disc? Rotary brush mower? Rotary finish mower?
Brand new? Used?
mpuller2
01-31-2006 13:28:07
 Re: What kind of mower? in reply to Tim(nj), 01-31-2006 12:09:30
Sorry, forgot the details. I'm going to mow a lot in town so a sickle bar is out of the question. A mower than could be pulled and PTO driven would be my first choice. 6,7 or 8 foot width would be nice. Hope this information helps with your suggestions. Thanks.
Sam#3
02-01-2006 03:59:16
 Re: What kind of mower? in reply to mpuller2, 01-31-2006 13:28:07
I'm sorry, but why do you consider a sickle mower more dangerous than a rotating blade throwing rocks, trash and the kids lost toys?
From my recent experience a pull type rotary is the most awkward thing to maneuver in a tight place.
Tim(nj)
01-31-2006 18:00:48
A Woods C80 trail-type rotary mower maybe what you want. A single-acting cylinder off the Lift-All pump on your M will work on it, pressure up, gravity down, no need to plumb a return line. Some have a crank to raise and lower the wheels, but not as handy if you need to cheat a little to get over low obstacles or uneven ground.
caseyc
01-31-2006 12:53:29
yes he did leave it alittle open but being as he has an M you can assume there's no 3 pt and probably no hydraulics so that would eliminate alot of mowers/cutters/whatever. if the M does have atleast one hydraulic hookup then he'd have to plum a return and find a trail type sickle mower with a one way cylinder. if not then a simple pull behind something that doesn't need to be raised.
casey in SD
