Hi-Tensile Fence and Posts
Phil
01-22-2000 19:56:43
I am going to put up a hi-tensile fence and I have a couple of questions.
It seems as though everyone around me is pounding fence posts in nowadays. I don't have a pounder, is there any reason I can't dig the holes and plant them the old fashion way. Will a fence post in a dug hole (especially the corners) be strong enough or is there a "waiting period" to allow the filled in dirt to settle.
Also, to save money I am cutting up some of the locust trees on my place. What is the minimum diameter that I should use as a fence post? When I cut the trees is there an easy way to get the bark off. Do I try and get it off immediately or should I wait and let it come off by itself.
Thanks,
Phil
Bill OH
01-24-2000 10:36:35
 Re: Hi-Tensile Fence and Posts in reply to Phil, 01-22-2000 19:56:43
Pounded posts have been tested to be ten times less likely to pull out than any other type, including set in cement. Good news is you can widely space the posts, I've heard in Australia they set them 100 ft. apart on the ranges. Folks around here tell me pounding is the only sure way to go on high tensile, they've seen hand set posts popped out and hanging in mid air from the wire. Trick is to get someone to do the work, but well worth it. Good luck!
Buck
01-23-2000 10:51:19
This was a never ending task when I lived on the farm with Mom and Dad. Cut the locust in the winter,skint the 3'to be put in ground so bark would be left in woods.Dad was very particular about keeping the fields and fence rows clean. skint area for wire after post were planted. Corners,pull and brace post need to be larger. Dad wouldn't allow any post further apart that 8' but now they go much further. Alot of that fencing is getting to be 50 years old . Most last around 30 yrs.
kevin
01-22-2000 20:36:16
There is no reason you cannot set your posts by hand provided you set them deep enough. You can set the corner posts also provided they are of sufficient diameter and braced properly. Follow the specs of the hi tensile mfg whose products you are using for specs paying particular attention to post diameters, depth, etc. Failure to follow their suggestions could result in your posts coming out of the ground.
No waiting period, but tamp the living daylights out of it or you'll have a loose post.
Locust makes good posts provided it is not blighted. Post diameter between corners should not be less than 6-8", or as split. Use your biggest unsplit posts for corners, gates, etc.
Easiest way to get the bark off is to use a sharp axe or hatchet and remove the bark where you plan to drive your fence staples, let the remainder above ground dry and it will peel off easily so long as your wire is not touching and thus holding it on. It is very important to remove the bark all the way around the post for the portion that is to be below ground.
I've done it both ways and was taught how to hand set by my grandfather who hand set utility poles for the local electric utility and I prefer hand set posts to those driven.
dross
01-24-2000 05:18:17
 Re: Re: Hi-Tensile Fence and Posts in reply to kevin, 01-22-2000 20:36:16
Dad always said if you got dirt left over you did it wrong. tamping is a pain but it's the difference between getting it done and doing it right. We go 5 ft. deep with 4ft. out of the ground, but that will depend on how tall a fence
you want.
