What's The Verdict?
Allan In NE
04-06-2006 16:09:11
Hi All,
What do you guys use to get cheat grass out of an established alfalfa field? Disc? Spring Tooth?
Thanks,
Allan
hayray
04-08-2006 05:34:57
 Re: What's The Verdict? in reply to Allan In NE, 04-06-2006 16:09:11
You definitely cannot get rid of grass in a established stand of alfalfa by running a drag or disc across it -- geeeez.
I use Poast or Poast Plus on grasses, has to be sprayed while the grasses are under 6 inches and need additional applications through out the growing season, it is best on young newly established grasses, once you get a lot of tillering going on you keep having grasses sprout from the rhizomes. I often spray poast in combination with pursuit or raptor.
With palatable grasses like orchardgrass it may not be economical to spray but if you have something invasive like cheat then you may get some benefit, you may in that case consider the round up ready variety if you want to bend your wallet a bunch.
Allan In NE
04-08-2006 06:23:48
 Re: What's The Verdict? in reply to hayray, 04-08-2006 05:34:57
Huh?
Farmers have been draggin' aging alfalfa fields since they invented the tractor. :>)
Allan
hayray
04-09-2006 05:02:51
 Re: What's The Verdict? in reply to Allan In NE, 04-08-2006 06:23:48
just because they are doing it does not mean it works, must be a Nebraska thing.
Ok maybe it works, but I have never heard of anybody doing something like that, don't you trash your alfalfa? And besides, tillage does not even kill all the roots, at least in my part of the country.
Allan In NE
04-09-2006 07:11:52
 Re: What's The Verdict? in reply to hayray, 04-09-2006 05:02:51
Hi Ray,
It's called "rejuvenation" and I really doubt that it is a "Nebraska thing". It is just a "pre chemical era" method is all.
I usually only do it once at about the fourth or fifth year of an aging crop. Have to do it early in the spring and not go very deep and not go very fast.
You'd swear that the whole darned alfalfa crop was ruined, but the alfalfa immediately comes back with a vengeance and just boils up outta the ground with renewed vigor.
Only this time, it comes back clean without all the weeds and grasses.
Allan
hayray
04-09-2006 19:41:11
 Re: What's The Verdict? in reply to Allan In NE, 04-09-2006 07:11:52
thanks for clearifying that.
Ray
Vern
04-07-2006 21:11:17
We used the spring tooth twice at 90 deg. angles & then followed up with a steel roller to pack the soil back down.
Vern
Nebraska Cowman
04-07-2006 07:32:36
I use a swather. Cut it early and it makes good feed.
caseyc
04-06-2006 20:05:16
hey old bud, this is the 21st century. round-up ready alfalfa!!!!
casey
ejr-IA.
04-06-2006 17:34:35
Thats some nasty crap I have that here in Iowa too.I have sprayed Pursuit for grass in alfalfa but don't know if cheat is in the same grass family as fox tail.
Leroy
04-06-2006 17:17:15
What is cheat grass?
Allan In NE
04-06-2006 17:20:18
 Re: What's The Verdict? in reply to Leroy, 04-06-2006 17:17:15
Hi Leroy,
Some guys call it military grass?
Allan
Leroy
04-06-2006 17:44:09
 Re: What's The Verdict? in reply to Allan In NE, 04-06-2006 17:20:18
Sounds like something we don't have here in Ohio in Corn belt
Allan In NE
04-06-2006 17:51:44
 Re: What's The Verdict? in reply to Leroy, 04-06-2006 17:44:09
Yeah,
Come to think of it, I remember someone saying that the Calvery hauled it in here back in the 30s or 40s in their horse hay.
Nasty stuff not good for anything except sheep feed and ruining a good hay crop.
Allan
