Rotavator Driveshaft
8nva
04-11-2006 20:55:59
Just picked up an old Howard Rotavator that appears to be made to mount directly to the pto of an 8N tractor. Price was right, free to a good home. Only part missing is the shaft that goes between the PTO and the gear box. Looks like a three-toothed dog clutch in there that would ratchet in one direction. Leads me to believe the shaft might have been spring-loaded. The machine number appears to be D10880 and it's about 48" wide with a single tire and depth adjuster.
My 8N has a sherman over-under and I know the transmission also changes the PTO speed, but I don't need to run 6" deep and 12-MPH. For a small garden plot, I'd like to see if it's worth getting this little tiller working. A plow and disc would be overkill for what I want to do. Anybody have a drive shaft for one of these?
Keith-OR
04-13-2006 09:36:16
 Re: Rotavator Driveshaft in reply to 8nva, 04-11-2006 20:55:59
8nva, here is what the front of my Howard Model E-60 looks like. Sounds like you are missing quitw a few parts for that one. Howard is still in production and have distributors out there. Just do a search on Google for Howard.
Hope these pictures help you also I have indicated where the ID tag is located.
If I can help further email me
Keith & shawn
Leftside of tiller taken from rear
third party image">Link
J. Schwiebert
04-12-2006 03:22:41
A good driveline shop can build you a new shaft or a good ag supply store may have the components so that you can build a shaft. Sounds to me you are describing an over running clutch which you will need because of the momentuim of the machine when you stop. Questions?
K.LaRue-VA
04-12-2006 09:49:29
 Re: Rotavator Driveshaft in reply to J. Schwiebert, 04-12-2006 03:22:41
You said the Rotavator mounts directly to the PTO so the shaft is internal? If that is the case, there is no room for a normal overrunning clutch, so it would have to be built into the way the shaft connects. You could attempt to make a shaft but you should have at least a picture or a parts diagram to go by. If your PTO shaft is the old 1-1/8. You could probably start with an 1-1/8 to 1-3/8 adapter and make a piece to weld on the end that will mate with the 3-headed ratchet-thing, but you will have to get the length right and make positively sure the overrunning feature will still work. Check and see if the Ratchet in the tiller is spring-loaded. Maybe use a lump of clay to make an imprint of the 3-headed part and take it to a machine shop?
J. Schwiebert
04-13-2006 08:24:11
 Re: Rotavator Driveshaft in reply to K.LaRue-VA, 04-12-2006 09:49:29
You can get 1-1/8 6 B yokes for the tractor. Also remember if you faricate a shaft you need to have 3-4 inches of slip built into it for sure.
