MF #33 grain drill
50bmg
04-23-2006 17:03:41
Howdy, just bought a nice 33 drill but wished I could get my hands on an operators manual.
Anyone have any clue where I could get one??
Thank you much,
Rick
phillip d
04-24-2006 16:44:11
 Re: MF #33 grain drill in reply to 50bmg, 04-23-2006 17:03:41
their simple to use,you just add or remove shims on both sides to change the pully sizes to change the fertilizer rate,but don't forget to re-adjust the belt tension after you do,that is very important(in-case you're wondering,yes,i did learn that the hard way one time),the most i could get on with ours was 220# per acre,which was usually all we needed here most times.Great working drills.One guy we planted for only wanted 8# per acre of hay seed and we had to close it to .5 on the seed box,1 usually gave us 14# which is where we ran it,i think we ran it at 7 on the seed to give us 160 of barley,phill
50bmg
04-25-2006 13:26:20
 Re: MF #33 grain drill in reply to phillip d, 04-24-2006 16:44:11
Thanks for the info, I plan on broad casting the fertilizer to get 300#/ ac for rec. siol test.
Thanks,
Rick
Christos
04-23-2006 21:56:56
Rick,
just as a side bar, if the AGCO/M-F Dealer can't find it, tell them its under tillage. You can also try E-bay.
Christos
50bmg
04-24-2006 09:14:31
 Re: MF #33 grain drill in reply to Christos, 04-23-2006 21:56:56
Thanks, rick
TomTX
04-23-2006 19:43:37
MF dealer.
Tom
50bmg
04-24-2006 09:15:43
 Re: MF #33 grain drill in reply to TomTX, 04-23-2006 19:43:37
Thank you,
Rick
