These days a field cultivator is _the_ soil prep tool. A disk is a specialized tool, everyone has one in the grove but rarely uses it, only when it is needed. The disk will help break up hard clods. It will cut up heavy trash, like lots of cornstalks, or heavy wheat straw. Other than that, it is a land packer & we have come to realize it does not make a good seedbed, more of a hard plow-pan in our clay soils. The field cultivator, with a 2-3 bar harrow attachment on the back of it, will make a much better seedbed 90% of the time. The only issue really is trash, as mentioned. Old units had the bars too close together. As they get newer, the bars got spaced farther apart, then a 4th bar was added on real new ones & all the shanks are spaced farther apart. For $1500 I would expect a pretty new unit with good spacing, harrow attachment, etc. 'Round here anyhow. Cultimultchers are not good in trash, they really plug up. Make wonderful seedbeds in clear dirt tho. Tillers tend to overwork the soil, using up hp & time. I think in small grain stubble, the field cultivator will work out for you fine. Chisel in fall, field cultivate in spring, and plant. For cornstalks, you would need to either chop the stalks with a stalk chopper (flail mower), or disk it several times, before chiseling it, then the field cultivator would should likely will handle things in spring. If I had to get only one, I'd go for the field cultivator unless there was a good reason for needing the disk - if you are in that 10%. --->Paul
