8N plow HELP
Don B in PA
01-25-2000 11:19:07
Really need recommendations on the best 2-bottom plow for an 8N. Will be plowing a few acres of gently sloping sod with some rocks.
Halbert09
02-04-2000 14:56:43
 Re: 8N plow HELP in reply to Don B in PA, 01-25-2000 11:19:07
You should be able to pull a 2-bottom no problem. Look for a Ford or Ferguson plow with 12" bottoms. I think you should look for the kind with the "throw away" blade type shares that cost maybe $10 for the replacement share. I believe the older ones, like in the picture someone provided have large points that are expensive and/or hard to find replacement for; maybe someone else could tell you better. I have also taken an old 12" Ferguson plow frame and changed it to Oliver Raydex bottoms by drilling a new hole in the beam and bolting the Oliver parts on; it plowed better than the original. Good luck.
B.C.
01-28-2000 10:36:44
When we had a 9N we used a single 16 inch Ferguson bottom that my granddad had found somehow. Worked fine. We had lots of rocks, and 1 bottom works better than two in rocks. Also, hp is not an issue then.
Burrhead
01-26-2000 09:36:18
The smallest bottom would be better for an 8n. The 14" should be all that you would want for your tractor. If you're in clay ground it won't pull a double bottom plow so I'd check the soil type and either get and old double disc turning plow or a single bottom plow.
I agree that an 8n looks really good with a double bottom plow, but in all actuallity it does'nt have enough ponies in the pen to plow anything but sandy ground with a double bottom.
Mike (Mpls.)'48 8N
01-26-2000 04:27:13
third party image
This picture says a lot. My Dearborn 2-bottom plow is the same only it has sat outside for over 50 years and is a 'dark rust' color.
