Blade for Farmall C
James
08-17-1998 07:27:08
I recently bought my first tractor, Farmall C, and I have been dreaming of a belly blade design using the dual rocker arms. I have seen belly mowers on this tractor, but not a blade. Are there blades out there for this application? Can anyone direct me to some pictures of one?
My idea is to have a floating arm on each side of the back axle with adjusting pin holes at the front ends to allow for different blade angles left, right, or straight. Then have some linkage connected to oppossite rockshafts to achieve blade tilt/lift.
My other idea would make use of the cultivator arms to mount a blade to. I currently only have one side.
Thanks for any thoughts and/or experience
Robert Campbell
08-26-1998 03:02:40
 Re: Blade for Farmall C in reply to James, 08-17-1998 07:27:08
: I recently bought my first tractor, Farmall C, and I have been dreaming of a belly blade design using the dual rocker arms. I have seen belly mowers on this tractor, but not a blade. Are there blades out there for this application? Can anyone direct me to some pictures of one?
: My idea is to have a floating arm on each side of the back axle with adjusting pin holes at the front ends to allow for different blade angles left, right, or straight. Then have some linkage connected to oppossite rockshafts to achieve blade tilt/lift.
: My other idea would make use of the cultivator arms to mount a blade to. I currently only have one side.
: Thanks for any thoughts and/or experience
Yes, IH made one. It also mounted to the front with the change of some brackets. I live in Maryland and I have one for sale. I will take $150.00 for it.
Bruce A. David
11-26-2001 18:37:01
 Re: Re: Blade for Farmall C in reply to Robert Campbell, 08-26-1998 03:02:40
: : I recently bought my first tractor, Farmall C, and I have been dreaming of a belly blade design using the dual rocker arms. I have seen belly mowers on this tractor, but not a blade. Are there blades out there for this application? Can anyone direct me to some pictures of one?
: : My idea is to have a floating arm on each side of the back axle with adjusting pin holes at the front ends to allow for different blade angles left, right, or straight. Then have some linkage connected to oppossite rockshafts to achieve blade tilt/lift.
: : My other idea would make use of the cultivator arms to mount a blade to. I currently only have one side.
: : Thanks for any thoughts and/or experience
: Yes, IH made one. It also mounted to the front with the change of some brackets. I live in Maryland and I have one for sale. I will take $150.00 for it.
