IH Model 100 Sickle mower
65 Oliver 1650
06-02-2006 17:30:26
Just wondering how good these mowers are? Do they have a pitman stick? I would just be using it to mow ditches around my farmette. Any responses are apprecitated.
R. John Johnson
06-03-2006 07:25:08
 Re: IH Model 100 Sickle mower in reply to 65 Oliver 1650, 06-02-2006 17:30:26
IH balanced head mowers are very good. They are pitmanless. You did not say if it is a trailer or 3 point type, but the cutting and breakaway mechanism is the same.
Check the wobble box for any play. With the pin in and attached to the knife, turn the drive pulley to see how much free play is on arm that drives the knife. A little here is ok. Remove the drive belt and try to wiggle the large pulley. There should be no play here. Remove the pin that drives the knife and check the arm for any vertical play. Very slight play here is allowable. If there is any major amounts of play in any of these areas, then plan on rebuilding the wobble box.
You did not say how long the bar is. With hard use the 9 foot bars have a habit of breaking off right at the point where it meets the wobble box. You may need to remove the grass shoe to inspect this area, but if you do BE CAREFUL. The bar will no longer attached to the wobble box at this point. It could fall and injure someone.
Check the breakaway casting. Look around the support for the vertical pin that the lift linkage pivots around. This casting can crack after too many hard acres.
Good luck
John
Keith T
06-03-2006 03:21:26
They were good mowers but it has some age .It has some age ,were made in the early 60,s and were supercededby the mod.1000,and later the 1300
balenced head mower.
Illinois Farmall
06-02-2006 18:53:20
I have a IH 200 sickle bar mower I use for mowing hay andit works fine. I don"t know what the differences in the model 100 and 200 are but mine does have a pitman arm. It does have a belt drive that runs off the PTO. Good mower in my opinion.
65 Oliver 1650
06-02-2006 18:38:38
Thanks for your help.
GBrad54
06-02-2006 18:31:35
They don't have a pitman arm- they are what is called a balanced arm mower and are driven by a belt- we have one we use for mowing ditches and laneways- works great because they will mow below level into a ditch and mow upright for triming hedgerows.
