new holland 461 haybine - belt replacement
bigslick
06-05-2006 15:01:14
I need guidance as to how to proceed in replacing the main drive belt driving the sickle bar.
It appears to be a major job>
Any help and or pics would greatly be appreciated.
Hay is growing and I need this to be repaired soon.
Thanks to all who reply.
Kelly C
06-05-2006 21:27:05
 Re: new holland 461 haybine - belt replacement in reply to bigslick, 06-05-2006 15:01:14
third party image
I suggest you go get a user manual from a NH dealer. It gives step by step instructions with photos.
Basicly, you place a jack under the left side of the header to support it.
Remove shields ( if you still have them)
Disconnect the reel and roll drive chains.
Remove the bearing and flang from the right end of the shaft coming from the gear box.
Remove the left wheel assembly, including the out side and inside wheel plates as a unit.
remove the gear box mounting bolts, then slide the gear box left.
Move the drive sheave right to get clearence from the frame.
Remove belt from drive sheave.
Remove the knife head bolt.
remove the 3 pivot bearing cap screws.
Remove pivot bearing spacer.
Rotate the pivot bearing mout 180 deg.
Rotate the wobble sheave until its in upward possition.
Swing pivot arm out.
Slip the belt off.
Reverse to install.
Easy huh?
Dave F
08-07-2006 15:14:30
 Re: new holland 461 haybine - belt replacement in reply to Kelly C, 06-05-2006 21:27:05
Kelly - Thanks for the guidlines - went to my local NH dealer and he could not get a shop manual - but your instructions worked like a champ and tomorrow I will be back in the field - THANKS
Dave
Kelly C
06-07-2006 05:18:32
Oh and wile you have it all apart. You might as well replace the 2 chains with new ones and replace the right end bearing.
Rexalot
06-07-2006 08:19:48
 Re: new holland 461 haybine - belt replacement in reply to Kelly C, 06-07-2006 05:18:32
That looks alot more complicated than what I did on my 469...
