Hooking Gyro Mower Bush hog to JD Model 60
Adrian Kreeger
06-27-2006 08:48:11
I have a 1964 model John Deere Gyro Mower 3-pt hook Bush hog that I currently use with my JD 10-10 tractor. I would like to use this mower on my John Deere 60 but need a way to stabilize the mower side to side as well as control mowing depth. Any ideas on how to do this would be greatly appreciated.
Bob
06-27-2006 10:52:10
 Re: Hooking Gyro Mower Bush hog to JD Model 60 in reply to Adrian Kreeger, 06-27-2006 08:48:11
Trade it for a pull-type Gyro-Mower.
Adrian Kreeger
06-27-2006 14:40:19
 Re: Hooking Gyro Mower Bush hog to JD Model 60 in reply to Bob, 06-27-2006 10:52:10
Thanks for the reply. Unfortunately, with the amount of backing and mowing that I do, a trailer-type bush hog would be less than ideal. Any other thoughts?
Adrian
RustyFarmall
06-27-2006 18:09:54
 Re: Hooking Gyro Mower Bush hog to JD Model 60 in reply to Adrian Kreeger, 06-27-2006 14:40:19
The later JDs had sway blocks for the 3 point, don't know if your 60 has them or not, but the sway blocks could be positioned any number of ways to allow the hitch to sway if needed, or not sway if that was necessary.
Adrian Kreeger
06-28-2006 09:25:09
 Re: Hooking Gyro Mower Bush hog to JD Model 60 in reply to RustyFarmall, 06-27-2006 18:09:54
Any idea what a sway block looks like? A photo would be helpful if you have one.
