Cast vs. Razor Shares
Don (8N 143633)
02-06-2000 05:13:46
True or not? An older Dearborn moldboard plow with those "real pointy" cast shares should be avoided? Where as a newer Dearborn or Ford "Economy" plow with razor shares is the way to go? If you have the older cast shares, is there ANYWAY to find parts for, retrofit to razors, etc. etc.? Could you put on whole new bottoms from another manufacturer and expect decent performance? Would really appreciate any guidance on this one.
Tim(nj)
02-06-2000 11:07:02
 Re: Cast vs. Razor Shares in reply to Don (8N 143633), 02-06-2000 05:13:46
Cast shares from any manufacturer are difficult to come by these days.
I don't know if the throw-away "razor" shares are interchangeable with the cast shares. It is possible to put a later style frog on the plow, but cheaper and easier just to look for a plow that already has the throw-away type shares on it. Why limit yourself to a Dearborn plow? Ferguson plows were similar. MF kept making that style into the 60s. My grandfather used a two-bottom JD 3-pt plow on the NAA, liked it better than the Dearborn, probably because it had safety-trip bottoms. Think it was a 2-bottom 416. I still have a 3-bottom 416 that he used on the MF65.
