paying for hay baling
730virgil
08-08-2006 11:06:27
what would be fair price for neighbor cutting ,raking and baling 8 1/2 acres of pasture for hay it made about 400 bales last time . he provided the gas and twine .
730virgil
08-09-2006 21:26:06
 Re: paying for hay baling in reply to 730virgil, 08-08-2006 11:06:27
thanks for input guys. i should have said pasture had been in corn when i seeded it to grass . is good laying ground easy to work . only reason i have it in pasture is i have very little rough ground
Steve KS
08-09-2006 15:39:54
Am I reading it right that you provided all of the equipment and he just provided labor, fuel, and twine? If so, none of the custom rates from the extension would work b/c they all figure using their own equipment. Maybe cut that rate in half?? That's a tough one, doing it like Old says on shares is probably the easiest, but if he used your equipment, I would think maybe a 50/50 or even a 1/3 2/3 the other way with you getting 2/3 would be closer.
JOHN J. ARNOLD
08-09-2006 10:35:16
TRY THIS WEBSITE FROM OHIO STATE--PRICES MAY VERY IN YOUR AREA.
Link
My son just did some for $0.85 per bale, dropped on the ground. That includes mower/conditioner, tedding & raking. Not worth it, as fields turned out to be more like a jungle.
Seth_ia
08-08-2006 18:42:26
One thing to note is that some people won"t bale pasture, too many field hazards. And I"m one of those.
730virgil
08-08-2006 14:46:52
neighbor has thrower on baler so bales are on wagon . i will put them in barn . a dollar a bale has been suggeted by local farm accountant . hay made on shares locally is 50 - 50 . that comes comes out to about a dollar a bale for this time of year locally .
730virgil
08-08-2006 14:45:40
neighbor has thrower on baler so bales are on wagon . i will put them in barn . a dollar a bale has been suggeted by local farm accountant . hay made on shares locally is 50 - 50 . that comes comes out ro about a dollar a bale for this time of year locally .
Beck
08-08-2006 14:21:12
I think the fairest way to charge is on a per bale basis. I like TimS's figure of $1.00-$1.25 per bale. However, it would depend on where you are located. In a normal year(not this year), square bales of first crop only sell for about a $1.50-$2.00 per bale in our area. Also you didn't specify if the neighbor would be delivering the hay to your barn and stacking the bales (alot of work). I would have to add extra per bale for that versus just dropping them in the field for you to take care of.
Jerry/MT
08-08-2006 13:48:12
I had my hay put up and the charges were $20/acre for mowing/conditioning, $5/acre for raking and $10 a bale for large round bales that averaged 1320 pounds.
Kelly Campbell
08-08-2006 12:23:25
I was charged 1.35 for bailing only last year, all depends on what someones time's worth....
old
08-08-2006 11:45:23
Common thing in my area is for the guy that owns the land he gets 1/3 of the bales and the guy baleing it gets 2/3s of the hay. Of course it changes if the land owner does things like cut and or rake but thats going rate in this area
IH2444
08-08-2006 11:32:03
Who gathered and hauled the hay ?
I would think at least $.75 to $1.00 per bale.
Iowa Jim
08-08-2006 11:31:46
I'd charge at least $1.10 per bale and want the entire years custom work. Price per bale goes up with each cutting since you do the same amount of work for decreasing bales.
I am leaning to charge by the hour for custom work, but have not yet formulated pricing.
Jim
TimS
08-08-2006 11:57:50
 Re: paying for hay baling in reply to Iowa Jim, 08-08-2006 11:31:46
Around here custom square baling is $1 - $1.25 a bale for cut/rake/bale.
You can contact your local ag extension agent and they should have pricing sheets you can get, I got them for our part of Missouri.
You will need to adjust for rising cost of twine and fuel of course.
Some folks charge per acre for mowing, mowing/conditioning, raking. Then a fee per bale on top of that.
edchainsaw
08-08-2006 18:51:29
 Re: paying for hay baling in reply to TimS, 08-08-2006 11:57:50
I went a long time ago to charging by the hour for everything but baling..
I was tired of seeing the guy with the smooth field pay more than the guy that made me run ruts and stumps and around trees...
I think I am really fair with $30/hr for disc mower..
