Pull Type Bale Wagons
4010s
09-09-2006 14:56:11
Been researching balewagons for a few years and finally looking into purchasing one. How much difference is there between the 1033 and 1037? I believe the 1037 has a hydraulic rolling rack but is there any other major differences? Is there a remote fender control kit available for the 1033? Any suggestions appreciated as well as if anyone knows where to find a good used 1033 or 1037 around Iowa or midwest.
kyhayman
09-09-2006 16:17:07
 Re: Pull Type Bale Wagons in reply to 4010s, 09-09-2006 14:56:11
The 1037 is the updated version of the 1034. Main difference between the 1033 and 1034 is how the rolling rack retracts and the lack of the single bale unload feature on the 1033. I've had a 1033 and a 1034. Wish I hadnt sold my 1033, the hyraulic retraction is more hassle than its worth, and I have only used the single bale unload once in 8 years. As to locations, I'm a repeat customer of Roeders in Kansas. Not sure where else to get one though I see them all over in points west and Canada.
4010s
09-09-2006 16:41:58
 Re: Pull Type Bale Wagons in reply to kyhayman, 09-09-2006 16:17:07
If I read your post correct, the 1037 will single unload then?
kyhayman
09-09-2006 23:50:18
 Re: Pull Type Bale Wagons in reply to 4010s, 09-09-2006 16:41:58
That I can not confirm, somewhere I have a book on one. If I remember correctly, the single unload feature became an option with the development of the newer 1037 series wereas it was standard on the 1034.
noel from nm
09-10-2006 09:12:49
 Re: Pull Type Bale Wagons in reply to kyhayman, 09-09-2006 23:50:18
I have a balewagon that holds 36 small bales. Did it have a number at one time or was it built before NH owned the balewagons?
kyhayman
09-10-2006 09:30:45
 Re: Pull Type Bale Wagons in reply to noel from nm, 09-10-2006 09:12:49
The 1002, 1010, and 1012's held 56, Thats the earliest Im aware of from NH.
