suggestions for haying equipment
Addy
10-01-2006 16:42:43
Hi all,
Due to a lack of anyone local to cut hay for less that 2/3 of the bales we"ve decided to bite the bullet and do it ourselves. That said, we are clueless. We"ve tried to get information from a couple of old hay guys, but they aren"t interested in giving away their secrets...so here are the details.
Small area (20+ acres) in northwest Oregon, mostly flat, Ford 841 tractor, lots of determination. We want small 60-70 pound bales.
Question: What is your suggestion for equipment? Brands, sizes, and any helpful input? We would be quite happy with used equipment so any information would be greatly appreciated. Worst case scenario is we screw up a year"s worth of hay and best case is we actually get to keep more than a third of what gets baled!!!
Thanks in advance.
Addy
Chief 83
10-02-2006 20:43:41
 Re: suggestions for haying equipment in reply to Addy, 10-01-2006 16:42:43
I'm in SW Washington with small acreage also. I switched a couple years ago from a sickle bar to a drum mower. I'll never go back!
I use an old Ferguson 3pt rake and it works fine. I don't think the brand of a rake is that important, just so the bearings and teeth are in place it will usually get the job done. Since we live in the NW getting the hay dry is sometimes a challenge. The best think I've purchased is a tedder. It easily cuts a day off the drying time which with our weather can be critical. As for the baler just about any JD or NH will have parts availability. I have a NH 315 that just never misses. All balers seem to be a bit more expensive in the NW than other parts of the country. The Capital Press newspaper is a pretty good source for hay equipment.
MF Poor
10-02-2006 13:40:31
Stay with the basics. CHEAP, SIMPLE, COMMON.
If youbuy high dollar equipment for that small amount of hay crop, you might as well buy it from someone else.
Simple equipment that you can work on yourself.
The more common you equipment is, generally, the easier it will be to find parts or find people that can help you. Stay with brands that you see frequently.
My picks would be;
Mower(s) New Holland 451 sickle bar (or JD 350) A haybine would be nice, but hayin' was done for years without them. They're money pits when they get old. Just plain expensive when NOT old.
Rake;Again, New Holland 56/256 ect. You'll pay a few bucks to get a good one, but it'll last AND do a good job. There's a good reason why they sell high. They're about the best you can get.
Baler; I had a New Holland 273. Good to better than average, but I like Deere balers MORE. Find a nice 336 and you'll have a baler for life, no more hay than you're baling.
A tedder if you can find one will help a great deal. It'll make up for the shortcomings of not having a mower/conditioner somewhat.
Wagons; The more the merrier. With enough wagons, you can unload at your leisure instead of while you're in a rush to get hay off the ground.
If you're working alone, or short on labor, look into a bale basket. (Poor mans accumulator)
rbmporter
10-02-2006 13:30:10
A few more cents worth,
You can't beat the new Holland rakes (256 or 258), but where I'm from they still bring 1200. or more..I bought a JD 640 side delivery for $250.00 greased it and went raking, it works great!....spent $1000 on a 1219 MoCo Deere, still getting the bugs out learning to set it correctly to cut properly, otherwise an OK machine, 4 wagons @ $800.00 / wagon, and $1200.00 for an 851 NH round baler which works great. I do @ 25 acres too, and can get it mowed in 6 hours, raked in @ 2.5 ( my son @12 years loves to rake with his 1939 JD H ) and baled in less than 3 hours. Just for my own cows, it is still cheaper than buying hay. It goes for $30.00 for poor stuff to $50.00 for good grass hay. I bale @ 60 bales a year, not much but I paid for all of the equipment in what I would have spent for hay in 3 years. I enjoy too...Good Luck & have fun! Bruce
Addy
10-02-2006 11:22:25
Thanks for your input. This gives us a good starting point. I'll keep trying to find an "old" local for more information. We're heading off to a farm equipment auction this weekend to "browse" and see what is available. Probably won't buy anything until we can get some more research done, but you never know what might turn up. Thanks again for all your help.
Addy
Kelly Campbell
10-02-2006 09:00:12
If your looking into new or newer equipment you might want to look at a drum mower. There basically the same as a disc mower however they don not require hydraulics to lift the mower, it is lifted via the 3pt hitch.
Hay DR
10-02-2006 15:58:35
 Re: suggestions for haying equipment in reply to Kelly Campbell, 10-02-2006 09:00:12
third party image
Drum mowers are simple and give the operator the cutting technology of a disc mower at 40-60% of the cost of a disc mower. Any MFG's drum mower is more durable that their disc mower. PZ & Deutz Farr designed the first drum mowers in the 1960's. Some current MFG's selling drum mowers in the USA are CCM, Vicon, Fella, Reese, SIP & Agrostrov. They start brand new from $2,300 and up.
Allan In NE
10-02-2006 04:39:57
Two Suggestions:
1. Go with a mower/conditioner vs a sickel bar mower and a rake.
2. Drop the small square bale idea and think big round.
Allan
Joe in IN
10-01-2006 21:32:08
Well my 2 cents...
1: Cut 5 acres at a time. No more. I have 20 myself, I do currently have 8 acres down, but I always have problems with more than 5(I work an 8-5).
2: the key to a $300 baler is being able to fix them. They are $300 for a reason. They break(not that $5000 balers don't). make sure you have the wherewithall(sp?) to be able to fix one. My $300 baler got ebayed for $250, and I was happy.
3: Oregan is differnt than Indiana, but I bought a Hesston PT10 for $150. 9'3" moco. It works..err well until yesterday when a bearing went out. Two years of cutting for $150, not bad.
4: Wagons, 2. I got mine for $200 apiece. Try picking up 5 acres of hay. First cutting say, 60 bales * 5 = 300. I know 150 sucks, don't want to think of pickingup 300. 150 on a wagon would be really loading a $200 wagon, but(see #5) just unload in short order. Me I have 3 back them in the barn and unload before the next 5 acres is due.
5: Help. You'll need it. My 62 year old mother drives the tractor most of the time. Would be hard to do it without her. I did find some neighbor boys, (when available) who like to stack. I have to pay $9 an hour though. Without pushing it, you can put up 120 bales an hour, well worth it(then I drive..).
I'm sure I could think of other tid bits, but it is late...
Edd in KY
10-01-2006 20:04:36
Oh yeah. One last thing that I learned from my Father, a dedicated first generation hobby farmer. "Never cut all your hay at once". Cut only about 5 acres at a time. Then, If the weather goes bad on you, you will only lose about a quarter or less of your crop. Likewise, If your back goes out, or your tractor quits or your baler breaks, or you run out of twine, you don't lose the whole crop. Besides, after about 400 or 500 bales, you may need a day or two to relax, have a refreshment and contemplate your amassing hay stack.
The guys that are making hay for a living are forced to march to a different drummer.
Edd ib KY
10-01-2006 19:43:46
I was in the same spot about 4 years ago. You need only 3 things, a mower, a rake and a baler. A wagon would be a nice addition, but you can drop the bales on the ground and load them on your pickup later and take thim to the barn if you have to. A tedder helps if drying the hay is difficult in your climate.
Mowers. for 20 acres a good non-pitman sickle bar mower will work and will cost about $300 to $500 and you can also use it to keep the farm neat as well. Just slow down and get it done. Do the maintenance often and sharpen the sections frequently. For all the guys that tell you that you need a haybine or a disc mower ask them how the hell we mowed ten million acres in America for the last hundred years without them? Models .. try a MF 41, NH 450, 451 or 452, or JD 350.
Rakes an old side delivery rake will work fine. Expect to spend $300 to $800. They continue to bring good prices.
Balers. You have lots of choices. JD balers bring big premioum prices around here. NH are good solid units that work well and parts are very available. A NH 273 is a fine little baler. If you are on a budget, Massey, IH and Ford balers go for nothing at auction, but they are workable and should be able to zing thru your 20 acres if in good shape. To bale hay you need to be a decent mechanic.
Finally, You need a bale thrower about as bad as I need a super model and a Ferrari.
Dachshund
10-02-2006 06:15:46
 Re: suggestions for haying equipment in reply to Edd ib KY, 10-01-2006 19:43:46
Couldn't agree more! I'd like to have a haybine, but they are pretty pricey and for my spot, I can't justify one. Did a lot of acres this year without one. Start small and work up to what you can afford. I wanted a reel rake - but they are pretty pricey, too. I bid my time (and borrowed one) until I found a good side delivery rake in the weeds at a nearby farm. It's been sitting for 25 years, but I greased it up and went out to work it (I even cut down a swath of hay to check it out). I need a few teeth, but they are cheap - so far I have - $0 in it. The neighbor has a "back-up" NH 273 in his shed. He uses it once in awhile to keep it "limbered up", but mostly it sits unless his main baler quits. He told me he'd sell it to me in a "couple years" when he quits baling. There are a LOT of similar balers out there for cheap - IF YOU DIG AROUND. I also could never understand the big round bales, there is a lot of waste in them and you can sell (here anyway) squares for more. I may be just wierd, but a 60# square, to me anyway, is a lot easier to handle than a 1200# rounder. I don't feed cattle, but I wouldn't go rounds if I did. Anyhoo - just a rant! The main thing is, decide for yourself what YOU WANT and don't let people tell you what you NEED. JMHO
ny bill
10-01-2006 18:48:12
presuming that nw oregon would have rain issues as most places do, a haybine would speed drying time over cutting with just a sicklebar. also the haybine reel should help feed in less-than-perfect tangled forage. a new holland 467, 477 would be a 7' cut machine, which may suit your tractor size better than a 9' machine(nh 469, 479, 488- all similar design). nh 56 and 256 rakes have been around for years and work well with either 7 or 9' swaths. as to balers, i'd look for a nh 311 or 270/271 with a thrower. the 268/269 balers had too much of a tendency to make banana bales. the 311/270 and newer balers have a different feeding action than the 268/9. thats my perspective from living 250 miles from the new holland factory. another good baler is a john deere 336. the older 14Ts had limited capacity, and the curved pan kickers are 40 years old and worn out. hope this helps.
old
10-01-2006 18:12:24
BTDT with a ford 841, till I got bigger tractors. I have used a NH 460 MOCO behind my 841, and also an old JD-14T baler and an old IH rake till I got to old to trow bales and now I do big rounds and all the ford does now is mover them, my 841 has a big loader on it
Dachshund
10-01-2006 17:13:41
Everyone will probably give you a different opinion on this one! I scrounged around for and older sickle mower (pitmanless if you can find one), just found a Dearborn rake "in the weeds", and have a line on a NH 273 baler. Here in Nebraska, you can find good used balers for $300 or less. I don't mind using the same type of rquipment my Dad used when I was little, so I don't go for fancy - just what works. Don't go mega-bucks on 20-30 acres and you will come out ahead. IMHO New Holland Hayliners are the best balers made. Up until now, I have been trading haying for help with my neighbor - he puts up my hay, I help him with other stuff.
oland
10-01-2006 17:49:08
 Re: suggestions for haying equipment in reply to Dachshund, 10-01-2006 17:13:41
You won't go wrong with New Holland or John Deere when it comes to balers. I would go with which one you can get the best deal on and who has the best parts support in your area. As for rakes I used a New Holland side delivery rake for years but when it came time to replace it I replaced it with a 4 wheel rake. You can buy a new wheel rake for about what it would cost to find and fix up an old side delivery rake.
