JD model 44 trip plow
AllanR
10-02-2006 15:45:20
I can't remove the wheel on side of the plow that operates the trip. I removed the nuts,cap and pin, but the spoke wheel will not come off. What do I need to do to remove this wheel?
WILENK
10-03-2006 10:02:56
 Re: JD model 44 trip plow in reply to AllanR, 10-02-2006 15:45:20
hOWDY HAD THE SAME PROBLEM THIS SUMMER WITH MINE IT IS A TAPER FIT, I DID A SEARCH ON HERE FOR REMOVAL TIPS AND READ THOSE I ENDED UP MAKING A SIMPLE PULLER WITH THREADED ROD AND IT CAME RIGHT OFF BE CAREFUL WHERE YOU PULL SO YOU DONT HURT THE WHEEL. GOOD LUCK
AllanR
10-03-2006 17:06:47
 Re: JD model 44 trip plow in reply to WILENK, 10-03-2006 10:02:56
Thanks Guys I got the wheel off. I used a puller and it came off easy. The bolts inside of the wheel still had some of the original green paint on them.
55 50
10-02-2006 21:04:24
Why do you need to get it off? Does the trip function need repair? I have hydraulic lift on mine so not much help.
AllanR
10-02-2006 21:16:03
 Re: JD model 44 trip plow in reply to 55 50, 10-02-2006 21:04:24
I want to change the tire, clean and paint the wheel. The trip works fine.
55 50
10-03-2006 07:45:30
 Re: JD model 44 trip plow in reply to AllanR, 10-02-2006 21:16:03
I remember someone mentioning that the inner sleeve (called a land wheel box in the parts manual) is wedge shaped and the wheel is quite hard to get off from the "box" due to dirt, rust, corrosion etc. A puller may work, but probably hard to find a spot to get a puller to clamp onto. You may be able to accomplish your tasks with leaving it all together and using a generous amount of masking tape when painting.
