Super C mounted plow
36 A
10-24-2006 19:51:39
Posted on the IH board to. Dose anybody have a picture of a mounted plow for a C or super C.I found a two bottom plow and the beam numbers are 513532R1 is the long beam and 515003R1 is the short.No tail wheel and the hitch part pivots up and down.A two foot shaft with two pipe sleeves on the ends look as if they get clamped to.Thanks mark
mdntspec
10-26-2006 18:39:21
 Re: Super C mounted plow in reply to 36 A, 10-24-2006 19:51:39
posted some pics in the implement photo section of the plow and mounting brackets for C-295.
I have both C-295 and C-295A for my 200. Big difference is the mounting brackets used.
MM_TX
10-26-2006 12:17:27
third party image
These have the same rail numbers from C-SuperC impliments parts cat. They all have simular mounts. Hope it helps. mm
K. Lawrence
10-26-2006 09:04:40
i've got 2 plows for my 200 that fit C/SC. i'll try to post a couple photos next day or so.
El Toro
10-25-2006 17:39:21
Some of the Super C's had the fasthitch on their implements. I had a Super C with the fasthitch
and the 2 bottom plow. I like it since it was easy to connect to the tractor and to disconnect
when finished. I didn't need to get off the tractor. Post a picture and someone may recognized the plow. Hal
