BEST PLOW
HI SAM
02-24-2000 15:35:20
WHAT IS THE BEST PLOW THAT YOU HAVE OWNED I THINK MY 4200 JD IS THE BEST
larry h
02-25-2000 17:09:31
 Re: BEST PLOW in reply to HI SAM, 02-24-2000 15:35:20
no comparison we collect and use plows at shows the oliver is the most produced plow ever made ie. white-national- pittsburg-oliver-ford-moline were all oliver at some time also they are about the only one you can still get parts for off the shelf try thet with the others after they are 30 plus years old they also do the best job turning the sod and for ease of operation we hane 10 different ones now they still have the most resale value
Kemper
02-26-2000 20:48:02
 Re: Re: BEST PLOW in reply to larry h , 02-25-2000 17:09:31
I will have to agree with Larry, Its pretty hard to beat an oliver plow. But there are some others that get the job done.
Mongo
02-25-2000 16:23:44
I am an Oliver man but I will say that I had a John Deere 66 trailer plow that was the easiest thing to pull I have come across. That is right up until I broke it's back, now I am back to Oliver trip bottom 3pt plows.
ted
02-25-2000 13:20:55
I'd go with a white. Same as old oliver.
HI SAM
02-25-2000 14:40:17
 Re: Re: BEST PLOW in reply to ted, 02-25-2000 13:20:55
WE ALSO HAD A IH 4--14 PULL TYPE WITH HYD PULLED IT WITH U M-M DID GOOD JOB PLOWING UNDER VETCH.
john d
02-25-2000 12:27:56
We had a 4-14" trailing Moline plow that did the best looking job of plowing I ever saw. The thing wasn't built to turn right worth a darn, however.
Fm
02-24-2000 17:27:57
ANY White or Oliver plow. The IH little genius are really good, also.
Tim W
02-24-2000 16:43:59
Hi Sam, On the farm I grew up on we only plowed about 30-40 acres a year and pulled a #8 Little Genius 2 14" plow with a Farmall M (which I still have)in 4th gear. It did a great job in various plowing conditions. It would do about any plowing job there was. Tim
Chris
02-24-2000 16:43:05
I'll take a White plow any day of the week over anything else, especially a Deere.
