How to adjust a Cub plow
brian
03-12-2000 05:55:28
I just bought a plow for my International Cub and I need to know How to set it to strike out the first land. It dosen't look like it is adjustable and It will not pull it's self into the ground. Any Help would be apperated.
Jerry
03-19-2000 19:27:33
 Re: How to adjust a Cub plow in reply to brian, 03-12-2000 05:55:28
First, the drawbar needs to be reversed so it is towards the front of the rear axel. Only one pin in each side so it will float. The depth lever is attached to the tractor (I leave mine on) and tips the drawbar down through a connecting link. The chain from the lift arm only controls in ground, out of ground. It should hang loose when plowing.
My guess is that you probably didn't get the drawbar lever when you bought the plow. No lever, no deal.
Jerry
Fm...
03-12-2000 15:11:35
I think this question would get a better response from the farmall board, but I will give it a try. Do you have your drawbar set on "float"(only one pin in it per side)? is there two levers;/one lever and teh touchcontrol? if so use the lever to adjust up down. other than that I am not sure...
Wardner
03-12-2000 19:29:36
 Re: Re: How to adjust a Cub plow in reply to Fm..., 03-12-2000 15:11:35
third party image
This is the draft control for a Cub. If you do not have this, you won't be able to plow with your Cub.
