24 T baler
4010boy
04-13-2007 08:41:32
Will a JD 24T that is currently using the biodegradable twine still work and tie consistently with nylon twine.
Mike (WA)
04-13-2007 12:49:56
 Re: 24 T baler in reply to 4010boy, 04-13-2007 08:41:32
Only way to find out is to try one bale. Knotters have to be pretty tight to work on plastic, and sisal is much more forgiving. Be sure the twine knife is sharp before switching- that's probably the single greatest cause of missed knots. Are you presently getting good, clean cuts, with both string ends the same length out behind the knot? Also, don't try the plastic as the first twine of the season- run a bale or two of sisal first, to get everything polished up, to give your plastic a fair chance to work.
