2 blade bottom plow
Cary Kennedy
04-22-2007 11:33:28
third party image
Good day group,
I am considering buying this cat1 2blade bottom plow. Any comments? How much do you think it is worth? rusty but looks solid.
Ultradog MN
04-23-2007 15:28:39
 Re: 2 blade bottom plow in reply to Cary Kennedy, 04-22-2007 11:33:28
Interesting plow. Doesn't look like a Dearborn or Ferguson. Those were the most common of the 3 point plows. Any tags on it anywhere?
Plow doesn't look to be in bad shape. Missing the tail wheel though. The moldboards look short compared to what I'm used to. Still will work for you.
It's worth $150 easy.
El Toro
04-22-2007 15:43:56
third party image
Some sandblasting and several coats of an epoxy primer with several coats of acrylic enamel or PPG's Omni single stage poly urethane it will look new. The plow on this tractor is 71 years old. Hal
jmixigo
04-22-2007 15:01:36
If it is as solid as it looks in the picture, it would bring $250 to $450 at most Southeastern auctions. If it's under $200 an you don't want it, I do.
John (MO)
04-23-2007 08:11:32
 Re: 2 blade bottom plow in reply to jmixigo, 04-22-2007 15:01:36
WOW!!!! At most farm auctions in the midwest I doubt it would bring $100.
