help
aaron1
05-05-2007 22:10:20
I GOT A LITTLE GENUIS 3 BOTTOM SOD PLOW I USE IT LAST WEEK AND I CAN NOT GET THE LAST LAY TO GO AS DEEP AS THE FIRST TWO LAYS AND I TRY TO MOVE THE LEVER ON IT BACK ONE STAYS THE SAME 3 X 14 PLOW USE TO WORK. ASAP
georgeky
05-05-2007 22:35:51
 Re: help in reply to aaron1, 05-05-2007 22:10:20
Are you pulling it with the same tractor as before? The hitch needs to be adjusted for different tractors with varying drawbar heights. Is your ground extremely dry they don't tend to go in the ground very well in late season after ground toughens up. A manual is available from Binder Books that gives all adjustments for this plow. Just search Binder Books and click on iplement manuals.
