hesston pt 10
460d
05-22-2007 19:06:44
Just bought a mower conditioner that is a hesston pt 10 anyone have experience with this line of mower some pro and cons things to look for thanks for all the advice and comments I am a IH type of guy but $$$$ is the reason I have this now
Gerald J.
05-23-2007 08:41:29
 Re: hesston pt 10 in reply to 460d, 05-22-2007 19:06:44
Make sure the right hand end guard rides tight on the sickle, else it will plug. It takes a shim to fit right there and that's easily missed when that guard is replaced.
Watch for the pressure links bowing out and chewing on the main drive belt.
That main pitman oscillates on a pair of tapered roller bearings, and is very quiet when they are in good shape and loaded properly.
IH sold it too, or Case seems like they called it a 489 or 789. That's on the cover of my parts book which is at the barn about 8 miles from here. Whether they could come up with parts I don't know.
The sickle head won't last as long as the sections.
If you lay the windrow out as wide as possible and rake before baling, you will bale a day sooner.
Bale the narrow windrow the same direction mowed and it will come up 100%.
Gerald J.
Larry NE IL
05-23-2007 08:02:04
Joe's got it right! Keep checking the pitman connection bolts, especially down at the wobble box. They come loose easy and make a mess if they come out. Stay out of wet hay, it'll really plug up there.
I keep a 5' bar with to turn the rollers back when it plugs up...and it will.
Joe(TX)
05-23-2007 05:43:38
I've used one for 15 years now. Will plug up easier than some cutters. Sickles are expensive.
Make sure the pitman drive is kept tight or it will beat itself to death. If the sicle binds it will tear up too. The ones with the u joints on the pitman are the later ones and hold together better. The early one had the ball and socket joints.
