Dearborne/Danuser auger questions
Leon Kasdorf
03-20-2000 08:05:04
I just resued an old Dearborne "Danuser Digger" from a neighbor's field. The greabox seems functional, but apparently somebody encountered an immovable object at some point and it bent the auger shaft, and bent the left mounting arm.
Visit this page to see photos...
My questions are:
1. What are you suppose to do with the long mounting arms? I just stick them beneath the axle, but they have holes at the end and look as though they are suppose to attach to something.
2. I am unable to raise the rig up high enough for the auger to clear the ground- apparently this is not mounted correctly.
3. What am I suppose to do with the top mounting arms? I attached them to my adjustable top link- but this doesn't quite look right, and it won't go high enough.
4. Do you think a welding shop would be able to heat the auger shaft and the mounting arm enough to bend them back straight?
5. Any idea of the date of manufacture, the history, or any other info about this unit.
Thanks!
Scott Hart
02-04-2002 15:07:14
 Re: Dearborne/Danuser auger questions in reply to Leon Kasdorf, 03-20-2000 08:05:04
Where can i find parts for my danuser post pounder?
Mike
03-30-2000 09:57:51
The arms do hook on a pin under the fenders on the tractor. You actually have the arms reversed and upside down. Instead of hanging from the lift arms they sit on top of them. The left arm (the one that is bent) is actually correct. The right arm should be bent just like it. You are also missing a linkage that goes from where you have the top link connected down to the lift arms, and also connects in place of the top link.
Jerry Danuser
03-28-2000 05:57:27
For all you history buffs out there following the chat of Leon about his old Dearborn Danuser
Digger, let me share the following with you. We have been in touch with him, and I want you to
have the same information. His serial number 6609 was shipped from our factory on 2-22-49.
There are no parts available for this old of a unit. Because of our legal world today, I hope you
cannot find any replacement parts, as you would be making something operational that is
considered unsafe by today’s safety standards. You can bring it up to the current safety
standards.
The best thing to do is to convert the old long arm diggers to the standard three-point hitch
configuration. This is accomplished by simply drilling the gearbox ears out to 7/8" diameter and
installing our Part Number 9049 (list price $372.65) which includes a boom and yoke for three-
point hookup. You will need our Part Number 9051 for Category I pin package (list price
$34.74) OR a 9052 for Category II pin package (list price $55.96).
We recommend you do not use the old long arm diggers because the units are before a time of
safety guarding. The old units did not have input pinion guarding, output spindle guarding, or
driveline guarding. You can cure all those guarding issues by purchasing our Part Number 7577 (net price $183.00).
This is our conversion kit which includes a new pinion, input guard, complete guarded driveline
all the way from the gearbox to the tractor, and an Auger Adapter Guard for 2-3/8" diameter
center column augers. When you install our conversion kit, you will end up with a current model
digger for which you can get parts. Once again, there are no parts available for that old of a
digger unless you update it.
Make an investment in safety! The current list price of a Danuser Model F8 Digger is over
$1500.00. Let me tell you from experience, most accidents occur with entanglement on the driveline or
auger. This entanglement risk becomes greater when our shear bolts are replaced with bolts
longer than those we recommend. This improper replacement occurs most often on machines that
are loaned out to someone who has not read the owner’s manual. Never use a bolt which
exceeds 4" in length as a shear bolt!
For you other Danuser Digger owners, give us your old serial number. I would be happy to send
you a current manual at no charge.
Thanks for your time in reading this, and don’t hesitate to contact us at www.danuser.com.
Jerry Danuser, President
Danuser Machine Co., Inc.
Bill in Mich
03-21-2000 23:00:09
My dad has the same digger that you have and I believe he has the original manual for it. You do have a few link parts missing. Email me if you would like a scan from the manual, Bill
Loren
03-20-2000 15:59:56
Leon; My dad bought a digger similar to this one in 1951 or 1952. I had one myself in the 70's and early 80's. They had a unique mounting system which helped make them dig a more vertical hole. It looks like someone may have "reengineered" this digger, also I think you are missing some of the mounting arms. The long arms attached to a pin under the axle where the stabilizer arms are attached and then two arms from the digger gearbox slid inside of these pipes. "RG" has some good advise, try to get a manual first,so you can see first hand how everything goes together.
bbott
03-20-2000 11:23:38
I've got one of probably ancient vintage...
they are pretty bullet proof...
Yes the company is still in business, still family owned and are very helpful.
I'm headscratching trying to figure out my mounting linkage too ! I've got more parts than
you do though !!!
Post another picture if you get it figured or
get some docs from Danuser!
bbott
RG (ks)
03-20-2000 10:55:44
Leon, The company is still in business in Missouri. Go to there website www.danuser.com email them and they will answer any questions you have. I think they even still have an owners manual for that model. One of the nicest companies you will ever do business with. good luck.
RG (ks)
Dave
03-20-2000 09:31:40
Leon,
Looks like you just aquired several attachments. From the first picture, I thought you just didn't need a toplink at all. From the second picture, I realized what you meant by long arms. Any idea what this was used on previously? Was it a high crop?
Almost looks like a front-mount if it didn't need a PTO. Otherwise, I would suspect that the long arms go over the axle and it may be upside down?
Dave
Leon Kasdorf
03-20-2000 10:36:08
 Re: Re: Dearborne/Danuser auger questions in reply to Dave, 03-20-2000 09:31:40
I don't think the whole thing is upside down, because the long arms have shorter arms attached that are angled such that they meet in the middle. If it was upside down, these shorter arms would drag in the ground.
If the ends of the long arms (where they hit the bottom of the axle) were extended down about a foot, this would push the digger up high enough.
Dave
03-21-2000 10:14:14
 Re: Re: Re: Dearborne/Danuser auger questions in reply to Leon Kasdorf, 03-20-2000 10:36:08
Leon,
Your right. If it was actually upside down the auger would point up. My hookup has a midmount point under the Tractor, so the long arms look normal if that were the case. I think the other posts to contact Danuser were on the mark. If there isn't a reasonable explanation for the mount, you could rig something with what you have and a good welder.
Dave
