Bush Hog Rototiller Oil Check?
Kevin Kissinger
03-22-2000 09:56:02
Just got a Bush Hog rototiller and have not received the manual yet. Some oil has leaked out of the gear housing. Anyone know how to check and fill the oil and what kind of oil to use?
SCOTT
04-06-2000 17:53:14
 Re: Bush Hog Rototiller Oil Check? in reply to Kevin Kissinger, 03-22-2000 09:56:02
FIRST DETERMINE THE MODEL AND THEN CONTACT BUSH HOG. 334-872-6261 ASK FOR THE SERVICE DEPT.
ted
03-23-2000 16:53:10
Most gearboxes either have a plug on the side (NOT the bottom--that's the drain) or has a vent cap with a dipstick attached to the bottom of it to check the oil.
Fill with oil till it starts to run out the hole on the side. The dipstick is self explaning.
If it leaks a lot (puddle on the ground the next day) and you use it alot you might want to replace the seal that's leaking.
Usually 90 Wt. oil.
Jeff H
03-23-2000 06:18:23
My RTS-50 Bush Hog tiller uses 80-90 gear lube in the gearbox and grease in the chain housing...
