Dearborn loader 19-61 hydraulic Cyl. needed
Tom Kwas
03-25-2000 15:48:23
Dearborn Loader Model 19-61
I am looking for anyone who knows of a supplier, remanufacturer or has a used main Hydraulic cylinder on this loader. I need to either rebuild this cylinder or get a new single acting clyinder that is 43" closed center of eyelets. Any and all help is appreciated.
Tom
Dave
03-31-2000 18:02:38
 Re: dearborn loader 19-61 hydraulic Cyl. needed in reply to Tom Kwas, 03-25-2000 15:48:23
Tom, I am 99% sure that single acting cylinders are no longer manufactured. My cylinders were leaking on an older ford loader. Have a quality hydraulic cylinder shop replace the seals and make a new shaft. If a dual cylinder would fit, air would have to be let in on one end which would create rust. My cylinders were about the same length, 1 3/8" rod. Totally rebuilt was about $175.00 each if I remember correctly. You'll be up and running in two days.
