Ferguson plow
wils slovenian
03-26-2000 16:08:26
I have a model 12-ao-28 sn# 4863 two bottom plow I would like to know whwn it was made and I also A'm looking for replacement points for both plows one has a casting number of 180962 and the other has 101246 on it and both have a number of 12bcao121dds cast on the back of the points I'm looking for a source if anyone can help I would be very grateful.
John Bukowski
03-31-2000 13:45:59
 Re: ferguson plow in reply to wils slovenian, 03-26-2000 16:08:26
wils,
Looks like a Ferguson Sod or Clay Plow. Shares are 12 for 12" bottoms
B for sod or clay type plow
C for Chilled iron metal
ao-121 don't know but is probably just ferguson part number system.
101246 is a ford dearborn 12" share (pn# 100246), Carburized steel also for their version of the sod or clay plow.
180962 I don't know
Moldboard should be stamped 12B-AO-110 if it has the original parts. This will help confirm the sod or clay type.
You could try Ford for shares; I don't know for sure that they are the same. I have been looking for shares for my 14-ao-28 type r general purpose plow, and my ford dealer says that the ford shares will not fit it. I am not sure I believe him as I also have an aftermarket ford share on my plow which works fine.
You could also check Central tractor as I see in their new catalog they are carrying ford solid shares. About half the price of the ford shares. I know they have the 14" and another share but can not remember if it was a 12 or 16" share. I will check tonight at home.
john bukowski
