ID loader
RA
03-28-2000 15:10:39
I found a loader in the woods and managed to acquire it but I have never heard of this brand. One tag says Martin Loader Pat. Pend. The second tag says Glenn M Rogers, 93 Lewis St. Lockport, NY and a number of 116 H. I wonder if this company is still around and what model and make of tractor this might go on. I also would like to know the color. I did find one little spot of paint that was red and this was one the clutch. Yes it has a clutch and brake assembley as it is operated off of the belt pulley of the tractor with a winch type lift using cables. The loader goes straight up and down on rails and has a set of forks that trip to dump. The side rails are just 19" apart so most of my tractors won't fit in between the rails IH and Allis appear to be to wide but my JD AR is around 17" so it might fit. Near the front of the rail is a spacer on each side about 6" high and 3" wide so that is it is narrowed up at this point to under 18"
Any info anyone could come up with would be really appreciated. Thank you.
RA
