Dodging the draft?
Brian
03-28-2000 20:08:03
How do I use the draft control on my MF135. I have seen other posts on this subject but it is not clear to me. What position is the other control lever suposed to be in? Do you set it so the tractor is laboring as hard as it can under soil and traction conditions? How does the tractor sense and compensate?
Halbert
03-29-2000 21:00:15
 Re: dodging the draft? in reply to Brian, 03-28-2000 20:08:03
You set it so that the implement is performing at the proper depth and doing the job correctly. If your only requirement is to go as deep as possible, then yeah, you could set as deep as the tractor will handle. The tractor "knows" by tension on the top link; the top link is tied in to the internal draft control. Other kinds of tractors may you some kind of tortion linkage on the lift arms, but not a MF135, I believe.
bbott...
03-29-2000 12:27:37
The 'outboard' lever is the draft control. 'Ferguson System' Draft control will attempt to maintain a constant (pulling) load on the tractor by moving the the 3 point lower arms up or down.
Theory was if you hit a tough spot while plowing, it would raise the plow enough to give weight transfer to the rear wheels and keep you going.
If you look at the point were your top link attaches to the tractor, you can see it almost looks like the end of a cylinder.
In a sense, it is... Thats where the load on the top link is sensed by Ferguson system and internally the 3 point hydraulics respond to it's inputs.
The Ferguson System sensitivity and response delay time are controlled by a small quadrant lever down by the floorboard. They let you tune how the 3 point will respond to changing loads.
In constrast, the inboard position lever will raise and lower the three point arms and hold them in whatever position you want.... come hell or hard ground.
When you're using Fixed position, the Draft control lever should be all the way to the rear....(and vice versa for things to work right)
Note that the inboard lever will 'creep' rearwards if you don't have the friction screw tightened enough...
A good investment would be purchase of an operating manual from our (gracious) site hosts...
Hope this helps. I don't plow much, but use draft control when I'm tilling and mowing.
AGEN
03-29-2000 21:26:52
 Re: Re: dodging the draft? in reply to bbott..., 03-29-2000 12:27:37
Very well said. This is an excellent description.
Dick L
03-29-2000 10:08:23
I was never around a MF 135, but the draft on any of my tractors is not manualy controlled. The shaft that the three point bottom links attach to has short arms that move as the machine being pulled ( plow )gets harder to pull. The through shaft for the bottom links has a spring device inside the rearend case that causes pulling weight to be forced down on the back tires which gives you more traction.
simple just call
03-29-2000 07:42:49
Bill Clinton
Burrhead
04-06-2000 10:31:05
 Re: Re: dodging the draft? in reply to simple just call, 03-29-2000 07:42:49
You boys are something. Bill was'nt dodging the draft, he had a college deferrment.
The one that was really dodging the draft was ole George W. Bush. Seems like if your Papa has enough money he can get you in a National Guard unit instead of real military service. That way he could stay close to the Mexico border where his dope was cheaper and easier to find.
As a veteran I can respect Bill more for going to school on his own, than I can George W for being a rich boy that his papa made him a weekend warrior wimp, and staying home doing drugs.
Glennb
04-04-2000 06:35:16
Regardless of what meaningless party affiliation they claim, it always comes down to the golden rule. Them whats got the gold, makes the rules.
Impartial Observer
03-31-2000 05:57:10
 Re: Re: Re: Re: Re: dodging the draft? in reply to But he didn't try to pork the USA !!!!!!!!!, 03-30-2000 12:05:44
Just the same, if the guy offers you a cup of coffee, make sure that it's cream that's making it light colored.
`Brian
03-29-2000 19:59:15
 Re: Re: Re: dodging the draft? in reply to No one likes a smarta$$, 03-29-2000 14:49:14
I dont know, but I thought it was kind of funny!
