Case 3pt plow
Drawbar
03-29-2000 20:59:35
I just bought an orange, 3 bottom, 3pt (cat 1) with the name CASE cast into one of the clamps. It has a rubber tired wheel mounted to the left of the rear most plow blade. Each plow looks like it has a spring trip system. Does anyone know the model? I'd like to replace worn plow parts (shins, shares, etc), Fleet/Farm store doesn't show parts for CASE plows, can i use other model parts by just matching up parts for close fit? How do you adjust the rear wheel height for plowing? thks.
Tim(nj)
03-30-2000 17:04:19
 Re: Case 3pt plow in reply to Drawbar, 03-29-2000 20:59:35
Shoup Manufacturing Company in Kankakee, Illinois, shows JI Case plow parts in their catalog. 1-800-627-6137, get a catalog.
They have replacements for JI Case 14" and 16" shares with numbers T39134, T39135, T39136. These shares have (3) 3/8" holes and (1) 1/2" hole. They also have replacements for JI Case 16" shares with numbers T63194, RCA6R, T63195. These shares have (1) 1/2" and (3) 7/16" holes. Shoup also lists JI Case shins, which you should replace at the same time you change shares.
drawbar
03-30-2000 17:44:36
 Re: Re: Case 3pt plow in reply to Tim(nj), 03-30-2000 17:04:19
thank you Tim(nj) very much. just the info i need. will get in touch with Shoup Manufacturing .
Draglink
03-29-2000 21:55:03
you probably have Eagle Hitch plow. I don't think it will hook up to cat 2 .
hardpan
03-29-2000 21:58:55
 Re: Re: Case 3pt plow in reply to Draglink, 03-29-2000 21:55:03
I think the Case eagle hitch had narrower lower arm spacing.
