IH 2001 loader
Al L. in Wisc.
08-22-2007 18:25:15
I want to restore my IH 2001 single-action trip-bucket loader and IH doesn"t make the metal hydraulic line that runs from left-to-right. Anyone have a source for this tubing; what material, wall thickness, etc. would someone recommend if I need to have something fabricated to closely match the original? Also, would someone have an original single front IH cylinder, in working order, laying around? This was an add on option that could be ordered through IH. Thanks in advance for your input.
Wisconsin Cowman
08-22-2007 20:19:48
 Re: IH 2001 loader in reply to Al L. in Wisc., 08-22-2007 18:25:15
Just have a hydraulic hose made up probably a lot cheaper. Unless you’re going for looks. Those steel lines don't last long on a loader.
Weldon K
08-22-2007 19:06:51
If you have damaged steel hydraulic tubing take it to a hydraulics shop. They would have the tubing in supply and could fabricate a new one just like factory original. Look in your telephone book Yellow Pages. If the tubing is missing from your loader , I have one that I can make measurements from.
Al L. in Wisc.
08-23-2007 08:30:54
 Re: IH 2001 loader in reply to Weldon K, 08-22-2007 19:06:51
Weldon K said: (quoted from post at 19:06:51 08/22/07) If you have damaged steel hydraulic tubing take it to a hydraulics shop. They would have the tubing in supply and could fabricate a new one just like factory original. Look in your telephone book Yellow Pages. If the tubing is missing from your loader , I have one that I can make measurements from.
[color=darkblue:c4b8dc0872][/color:c4b8dc0872]
Does your loader have single or double action cylinders; hydraulic bucket/factory (IH) or trip? I am curious, also, thanks for the information.
Weldon K
08-25-2007 13:18:00
 Re: IH 2001 loader in reply to Al L. in Wisc., 08-23-2007 08:30:54
Mine has double action lift cylinders and factory equipped hydraulic (single cylinder, double action) bucket dump. I have parts book and operator's manual if you need to see anything.
vernMN
08-24-2007 21:42:01
Mine has single action on the lift arms and double action on the bucket.
