ATV vs 3pt spreader seeder
larryo
04-02-2000 16:55:21
Has anyone out there tried to use a ATV 150 to 175 pound pull type of seeder / spreader? Will they work on a plowed and disked field without turning over? We have a 4wd ATV that should pull it OK. I have looked at new 3 point hitch fertilizer / seeders and feel they seem to be overkill for my type of use (1 to 2 acres at a time). I would like to hear about experiences with the ATV type and 3 point type of seeder / spreaders.
ward
04-06-2000 19:44:31
 Re: ATV vs 3pt spreader seeder in reply to larryo, 04-02-2000 16:55:21
I have used some ATV seeding equipment (spin spreaders) on small wildlife plots and had good success and little problems. Talk to your local ATV dealer to get info on the eqipment.
This is an ATV
04-06-2000 06:56:35
third party image
What you have is a dirt bike
scottie
04-03-2000 16:35:09
Hi,
For 2 acres of pasture use a garden tractor with a agrifab 125 spreader, might be the next size up not sure. You could get the next size up to pull with a tractor? what size tractor do you have? or if time is not important just use a garden tractor.
Scottie
larry o
04-04-2000 07:52:59
 Re: Re: ATV vs 3pt spreader seeder in reply to scottie, 04-03-2000 16:35:09
I have a MF 231 tractor and a Yamaha Kodiak 4WD
george s
04-04-2000 14:13:27
 Re: Re: Re: ATV vs 3pt spreader seeder in reply to larry o, 04-04-2000 07:52:59
I think you'll find the 3 point spreader is a lot cheaper than the ATV ones I've seen advertised,but those little 125# agrifabs for a hundred dollars work pretty good.I've even pulled one with a pickup in a pinch.Had to strap my son to the truck though to work the lever
