Baler ????
Thomas D. Hanso
04-03-2000 09:47:01
I need a baler for my WD 45 and have come across several that I would like input on. One is a NH model 66 with the Wisconsin power plant. The others are a JD 14T and a 24T. All things being equal, which would be my best best? I'll only be baling 2 acres for a couple more years. The NH has been shedded for all it's life...
Thomas D. Hanson
04-12-2000 12:35:27
 Re: Baler ???? in reply to Thomas D. Hanson, 04-03-2000 09:47:01
Call me stupid...
Everyone's advice was incredible, I ended up buying a NH Super 66 for $75. Not knowing what to look for, I spun this and that, made sure everything moved and was greased, all seemed great until a neighbor stopped by.... How did I miss the broken needle? The price around here for a new one, $129.. Local farmer 1, city boy 0...
Burrhead
04-12-2000 14:56:43
 Re: Re: Baler ???? in reply to Thomas D. Hanson, 04-12-2000 12:35:27
I would call another NH dealer. The needles here are less than 1/2 that amount. I called the other day and they were $54 each here.
Look around where you are and see if somebody has one junked out by the barn with good needles. Then see if you can get the whole thing for parts.
dave(ne)
04-07-2000 14:40:01
You guys talk about sharpening the hay knives. I thought the NH knives were self sharpening if adjusted properly. How do you sharpen them, take them out and sharpen with a file?
thanks dave
Burrhead
04-07-2000 20:03:35
 Re: Re: Baler ???? in reply to dave(ne), 04-07-2000 14:40:01
Naw the 66 is'nt self sharpening. I take the bottom knotter mount bolt out, roll the knotter all the way over to get to the knife, and sharpen with a file.
paul
04-07-2000 18:43:30
My 270 New Holland has done about 90,000 bales and we never touched the twine cutters. We got it used, so don't know how many before...
--->Paul
B.C.
04-06-2000 07:40:12
I would have to go with Ernie. I had a 14T and sold it when we moved. I have a NH 66 that became a parts machine for our NH 68. All were or are PTO machines.
I've heard more bad than good about Wisconsin V-4's. They can be a pain to restart when they're warm. My experience with the NH 66 itself was very frustrating. I put more money into it than I care to admit to try to get it running right. The NH 68 IMHO is a much better deal.
I would go for either the 14T or the 24T, with the prejudice towards the 24T all other things equal. If your WD45 is healthy and the PTO works okay there is not any reason to avoid a PTO baler. You should have power to spare.
Any of them would work. You should be able to get manuals and parts for any of them. I would bet the Deere's would be a better deal from what you've described.
Burrhead
04-06-2000 15:59:46
 Re: Re: Baler ???? in reply to B.C., 04-06-2000 07:40:12
Unless somebody has switched out the NH engine it should have an inline upright 2 cylinder not a 4V.
I've had both balers too, and for my own use I would'nt recommend a Deere to anybody just starting out. He might come down with Postal syndrome and come hunting you.
If you keep it adjusted right, and run it right the NH will keep baling right even when it's worn completely out, but you won't be able to keep the JD adjusted so it does'nt throw lop sided bales, break needles, break the twine, and jam the knotters.
A feller that is just starting out learning which type baler to use danged sure won't ever learn on a wore out Deere.
ErnieD
04-06-2000 18:41:02
 Re: Re: Re: Baler ???? in reply to Burrhead, 04-06-2000 15:59:46
Never had any luck with anything wore out. That said...
My Dad bought a 14T in 1961, new. It baled all the hay for our farm from then to about 1980, 10-12,000 bales per year. From 1967 on, I was 15 and my brother 12 did the haying and machinery fixing. In 1968 I bent up a set of needles when the feeder chain broke, got it timed ok, and it baled fine, until the feeder chain broke 1500 bales later. Had JD send a mechanic who put on a set of needles ($75 ea.) and adjusted the machine. Ran like new till the end.
My brother took over the farm and replaced the 14T with a 24T because it had a thrower. It continues to work well.
Secrets or hints:
1) Shed the machine.
2) Clean out the bale chamber, I found lopsided bales were caused by accumulations inside the "compression chamber". Adjust the hand cranks even number of turns.
3) Use 8000 rated twine on the thrower, 10000 twine if hand catching.
4) Use square knots to splice the twine bales, unravel and tuck the loose ends into the feeding twine.
5) Carry a spare bill hook for the knotter, and know how to replace it.
6) Keep the plunger and knotter knives sharp.
7) Keep the roller chains taut and lubed. 8) On the 14T the plunger stop is retracted by the needles catching a hook. The last year(?) a hinged lever was used and is superior. We had that mod installed in '62. Make sure the needle brake is adjusted and the needles won't drift back.
9) Keep your rpms up tying. If you don't have a tach, I remember ~58 strokes per minute on the plunger.
Don'ts
1) bale more than one fence post at a time.
2) bale green or damp hay for storage. We had a neighbor who would bale green hay to feed out immediately with a NH, but we could never do that with our 14T. Too much strain.
3) forget to replace the machinery guards
4) pitch the ball peen hammer into the field when you bend up ;the needles.
Burrhead
04-06-2000 20:31:10
 Re: Re: Re: Re: Baler ???? in reply to ErnieD, 04-06-2000 18:41:02
Ernie, you did'nt have any luck then, and it's 70 strokes per minute. You don't adjust the lop sided bales like you're telling him, nor adjust the chains that tight.
If he's found the equipment he says he has it's wore out. If nothing else, just from sitting outside they're rotted down.
I've had both balers myself that dang sho was'nt wore out, and he'll still lose a crop trying to learn how to run a wore out JD.
B.C.
04-07-2000 07:40:39
 Re: Re: Re: Re: Re: Baler ???? in reply to Burrhead, 04-06-2000 20:31:10
All I know is that the 14T I had was pre-owned by a number of people, one of whom had managed to rip the forward part of the bale chamber off and weld it back together. The rest of the sheet metal was in about the shape that sort of implies. When I gave the guy 225 for it I thought I was making a mistake. The knotter was covered with crud, and it really looked sad.
Cleaned her up, put in fresh twine, got some advice, greased what the book said (and the owners manual and parts book were readily available from the Deere place), and she worked. Most of what trouble I had was because I didn't know to keep the plunger knife sharp and adjusted. Put up 1000 bales that summer, and about that many the 3 summers after that. And I'd never had my own baler before, either. We'd had to have somebody come do that for us when I was a kid.
I am no great fan of Deere stuff, except that their parts support is what I'd judge anybody else by. And their parts prices ain't all that bad either. Go price a set of needles for that NH66 and compare that to the Deere prices.
And if you go with that 66, be sure all that knotter drive chain, wadboard drive chain, sprockets and mumblewoof are in good shape.
Burrhead
04-07-2000 13:24:15
 Re: Re: Re: Re: Re: Re: Baler ???? in reply to B.C., 04-07-2000 07:40:39
I came across wrong on the Deere part. What I was trying to say is that there are'nt any new antique balers like either of these unless you find one that for some reason has set in a shed for many, many years not being used since it was new.
I called JD and they could'nt find a source for new needle for the 14, but for the 24 it was $71.49 plus wait 3 days to 2 weeks after ordering them. I don't know if they use the same needles or not.
I called NH and the needles are $54.96 ea on the 66, and they have them in stock.
You're 100% right on the cleaning, sharpening and adjusting the baler before you use it.
I always think it's a good idea to pressure wash the baler, grease the unit, and spray oil on all the moving parts at years end. When I start to put it up for the year I check all the knotters, plunger, and pto shaft for wore out parts.
Next spring all I do is re-grease it, sharpen all cutting edges and adjust everything including the plunger back to specs.
I'm still running 1 NH 68 Hayliner twine baler, and it still does good. The wire baler was still doing good, but it got so hard to find wire around here I parked it.
B.C.
04-07-2000 15:12:54
 Re: Re: Re: Re: Re: Re: Re: Baler ???? in reply to Burrhead, 04-07-2000 13:24:15
Well, you got better NH quotes than I got when I went looking.
Back in '86 a set of needles for the 14T ran about $100 and I didn't have long to wait for them. It's hard to believe Deere's not supplying them anymore, but I'll take your word for it.
In '90 or so when I was fighting the NH66 I was waiting for a week or more for wadboard, and wadboard drive parts, to show up from New Holland out of Detroit. The dealer was in the middle of Ohio, which is not that far away.
Burrhead
04-07-2000 19:24:06
 Re: Re: Re: Re: Re: Re: Re: Re: Baler ???? in reply to B.C., 04-07-2000 15:12:54
Yeah our local JD has gone to pot since the independent dealers went out around here. You might get a little better deal if you have a independent dealer there.
So far both of our NH dealers are still Mom & Pop dealers. I get a better price and service both from NH.
B.C.
04-08-2000 15:01:41
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Baler ???? in reply to Burrhead, 04-07-2000 19:24:06
I was talking to regular dealers in both cases. Like I've said here and other places, NH list prices seem to run higher than Deere list prices on comparable parts. And I've had to wait longer for NH stuff at times than I ever did for Deere stuff.
Anyway...to the original topic. I believe any of those three machines would work. But if the guy has a healthy WD45, for reasons stated above I still think the 24T would be the better choice.
I once heard a guy up in Minnesota claim that a Case IH dealer told him that a new set of needles for an IH 47 would run $500. Maybe some of the dealers don't want to die poor.
Haybaler
04-07-2000 10:08:35
Mumblewoof????? OK gotta bite what is a mumblewoof, I've been around balers a while and broke a few, got me on this one.
B.C.
04-07-2000 10:22:05
 Re: Re: Re: Re: Re: Re: Re: Baler ???? in reply to Haybaler, 04-07-2000 10:08:35
Mumblewoof = Less than straightforward design.
Haybaler
04-07-2000 13:19:17
 Re: Re: Re: Re: Re: Re: Re: Re: Baler ???? in reply to B.C., 04-07-2000 10:22:05
Oh.
ErnieD
04-04-2000 18:51:30
If the JD's are not wore out, thats my choice. I cranked on a hand start wisconsin until my hands bled. For two acres, jeepers, we used a pto 14T behind a Ford Naa for 30A. On hills. Pick the one in best condition.
Mark A
04-04-2000 07:30:16
I think the 66 would be the way to go. We've had ours for about 6 yrs and do 12 acres three cuttings. We pull it with a Ford NAA most of the time. With it's own power you can adjust the tractor speed to conditions while the baler runs at 100%. You can also pull the baler with most anything. I have used my Suburban to pull mine, with the Air conditioning and AM/FM cassette I almost felt like I had one of them new tractors. It is hard to explain why I'm the only one who can drive when it's 95 and the wife is stacking the bales though. On a safety note you do have to get off the tractor to stop the machine. Does yours have the electric start? Mine is hand start.
Burrhead
04-03-2000 15:16:59
I like the NH 66 better myself. It's alot easier to keep adjusted and the parts are easier found and cheaper.
Them JD balers are good, but they're not as forgiving while you're learning to bale with them as the NH is.
