Old Time potato diggers
mark
09-25-2007 10:51:20
Have any of you ever used one of these contraptions? I wonder if they actually worked as advertised....or if they left a lot to be desired. I have wanted one for years and it is apparent that I'll have to go up north to find one...Michigan seems to be a tater growing area closest to where I live in KY. The type I want is ground driven...unless I could find a deal on an older PTO type. For me, this is just a toy to be used in the family garden....not looking to get into potato farming! I idea that a machine will bring all the spuds up, shake the dirt off and leave them in a neat row or let them fall in a bin...impresses me.
Clarkbug
09-29-2007 18:48:37
 Re: Old Time potato diggers in reply to mark, 09-25-2007 10:51:20
I have used one of these diggers before, for quite a few tons of potatoes in fact. I worked on a veggie farm while in high school and college, and this is the type we used.
My boss had two of them, one like the ones pictured, that just leave the potatoes on the ground. The other had a second section pulled behind it, that was an elevator. Up to 7 of us would ride on the back, picking off the clumps and vines and rotten potatoes. One person was the bagger, we used the burlap potato bags, hooked onto a chute. Two hung on the chute, and you switched bags when one was full, and set the full one in the soft dirt behind the digger. Lots of spuds dug with that thing. All were set up to adjust the depth with the 3pt hitch. If you dig too low, you just get clumps, and too high you cut the spuds.
I see them quite often these days up in NY, just driving past some farms. Also, there are some in the Want Ad Digest ( www.wantaddigest.com)
But they are only worth the pain if you have a LOT of potatoes!
Mathias NY
09-27-2007 11:10:48
My family has used an old 'Challenger' potato digger, one row, formerly horse drawn. Works ok behind a tractor. Doesn't take much power to pull, going slow enough is the hard part. If you have rocky ground be careful. The rocks can get jammed into the chain, which can lock the wheels and tip the digger over. We pull it with a 21hp John Deere 900HC.
There have been a few modifications in the 40+ years my family has owned it. Most recently we have eliminated the whole 'truck' assembly, and made a hitch for the 3pt on the tractor. Now the 3pt hitch raises and lowers the digger. It works too well to justify upgrading to one of those fancy PTO driven machines. Of course if we grew more than an acre of potatoes we might change our minds...
JK-NY
09-26-2007 16:46:15
I ahve used one - still have 2 ground drive one row diggers . Used one on 1-1 1/2 acre of potatoes a year till about 10-12 years ago.Ground drive diggers work ok- pto diggers work much better , esp in tougher conditions. Something else that works pretty good is a one row potato plow -also known as a middlebuster.You have to scratch around a little more to get all the potatoes but they work pretty good. Having proper row spacing is important for either - ground drive diggers and middlebusters work best with dead, dry vines and no weeds, if you have heavy green vines and/or weeds it pays to mow them off with a brush hog before digging.
JJ. in BC.
09-26-2007 09:57:27
This is mine that i used up until a couple of years ago on an acre of spuds every year, either a MF or Iron Horse not sure which. Works good :>)
third party image
Pete7
09-25-2007 18:27:40
Hi Mark...I use a ground drive potato digger made by IH (with a Super A) for my potatoes and onions. Works great in dry soil. I see them for sale on occassion on Ebay.
Pete
Cal Innes
09-25-2007 17:24:31
I have a PTO drive international one row and it works great... sure beats digging by hand. It digs them up, shakes the dirt off and deposits them in a row on top of the ground. I had paid 600 bucks for it 12 years ago and have not done anything to it except paint it. Cal
El Toro
09-25-2007 18:06:17
 Re: Old Time potato diggers in reply to Cal Innes, 09-25-2007 17:24:31
I don't think you will miss finding all the potatoes using a digger. Hal
plowboy 1
09-25-2007 17:14:01
`Boy, that"s a lot of money! But think about what it costs to do just about anything "round the farm. Whats it cost to put up hay by the time you pay for tractor, baler, rake, mower, tedder? And some folks cry about $2-$3 a bale!!
RayP(MI)
09-25-2007 16:49:14
We used a PTO powered JohnDeere digger for a long time when I was a kid. Although it was a one row, it could do a serious job of digging potatoes. Man I hated picking up those taters. too much like work!
Charlie M
09-25-2007 15:21:29
I use an old IH horsedrawn digger for several rows in my garden. Beats digging them by hand. Planted them with a 1 row IH horsedrawn planter. PTO diggers are way better than ground driven but usually will cost you a lot more to buy.
Lew Best
09-25-2007 15:07:13
I'd LOVE to find one within a few hundred miles of Texas; might even try using it sometime. mainly just 'cause "no-one else round here has one."
Lew near Waco, TX
El Toro
09-25-2007 14:34:21
third party image
Here's one that was sold. I should've had one years ago when I raised a lot of potatoes. I used my garden tractor to plow them out this year.
I had to rake after each furrow to uncover a lot of them. Hal
Jim in Ma.
09-25-2007 11:58:10
Years ago we had a one row horse drown one it worked pretty good. you can also use it for onions,it drops them on top of the garden to pick up after they dry.
You need about 20 HP. to pull it.
mark
09-25-2007 15:33:10
 Re: Old Time potato diggers in reply to Jim in Ma., 09-25-2007 11:58:10
Did y'all have to hook 20 horses to it? LOL!
Causes me to ponder another point.....I wonder...how many good draft horses would it take to equal the pulling power of say a 75 horse tractor..low speed of course, in a dead pull. Go ahead and give the tractor 4 wd...the horses use all 4 feet!
Ok...back to tater diggers....that Oliver is exactly what I'd buy if the price was too high.....any idea what one like that would sell for?
georgeky
09-25-2007 20:28:04
 Re: Old Time potato diggers in reply to mark, 09-25-2007 15:33:10
Mark, a good team of heavy draft horses will out pull most 50 to 60 HP tractors on a dead short pull. Have watched them in pulls drag 12,000 pounds or more.
mark
09-25-2007 22:01:07
 Re: Old Time potato diggers in reply to georgeky, 09-25-2007 20:28:04
george,
I've never watched a team work....seen them of course, but so far as working..no.
I did see a yoke of oxen dragging saw logs. This pair were big brutes...probably 1800-2000 pounders. They had a saw log behind them that was at least 36" in diameter and probably 10 feet long. They walked away like it was a toothpick. They just mosied along like they were hooked to nothing! I have no idea what it weighed, but I was dumbfounded at the sheer power they had. Not built for speed...but brute strength!
georgeky
09-26-2007 00:24:15
 Re: Old Time potato diggers in reply to mark, 09-25-2007 22:01:07
mark, a guy right in front the truck stop at the Mt Sterling exit off I-64 breaks Belgiums to sell to the Amish. He raises 70 acres of tobacco and does all the cultivating with horses. I like to just sit and watch them work. Seen a guy in Harrison county pulling a Hahn Hi Boy with a horse. It had a ground drive pump and could spray tobacco very well with it.
mark
09-26-2007 04:41:03
 Re: Old Time potato diggers in reply to georgeky, 09-26-2007 00:24:15
george,
70 acres of tobacco is a lot.....even with a tractor. I know there are folks down in the Bluegrass that raise several hundred acres..... which is akin to a bean farmer raising 6-8,000 acres of his crop. Tobacco is so labor intensive..... .I don't miss working in it one bit! I used to know old-timers who would farm 4 or 5 acres of tobacco with a horse or mule.....that seemed like a big crop to me for one feller to follow a farting mule all day long in the heat. Those old folks always wore bib overalls and a long sleeve shirt and a wide brimmed felt hat..... clothes that make me sweat just thinking about it. Then there was always a contest to see who could cut the most sticks in a day. The old folks wouldn't stand for none of this sloppy work where the tobacco fell over..no sir, you drove that stick and if it fell over, you set it back up. A good man could cut a thousand sticks and I have heard of some cutting more....but I have seen their work.....half the tobacco laying on the ground. My belly is too big and my back too worn out now to stoop and cut tobacco all day now. I'd be lucky to cut 300 sticks. Ain't nothing like walking those tier poles in the top of a barn during housing time is there! Only about 140 degrees up there..hehe! Nothing but brute work...don't miss any of it.
El Toro
09-25-2007 16:10:32
They were asking $2750.00 for the Oliver digger.
They may have received that much. Hal
mark
09-25-2007 16:17:11
 Re: Old Time potato diggers in reply to El Toro, 09-25-2007 16:10:32
Wow! I could buy a lifetime of spuds for that kind of money.
El Toro
09-25-2007 18:02:17
 Re: Old Time potato diggers in reply to mark, 09-25-2007 16:17:11
If you had about an acre of potatoes it would sure come in handy. Money is no object for some people. Hal
mark
09-25-2007 19:55:28
 Re: Old Time potato diggers in reply to El Toro, 09-25-2007 18:02:17
Hal,
Some folks have deeper pockets than mine..or maybe just want something worse than I do. One hundred pounds of seed potatoes will make all the taters me and the extended family will use. I spent more money killing the damned bugs than the last crop of potatoes I raised, was worth. Like Lew in Waco said...it's just something to have because nobody else (in these parts) does.
I never was able to raise big spuds for some reason, but I had an old neighbor who used to raise some whoppers. I asked him once what his secret was...he said, "pour the fertilize to'em." I know he wasn't too scientific in his approach..but it worked. He used 19-19-19 and then side dressed with ammonia. I would have figured they would have been all vines by using that much nitrogen..but the tubers were huge and plentiful.
El Toro
09-26-2007 03:55:14
 Re: Old Time potato diggers in reply to mark, 09-25-2007 19:55:28
I raised 6 rows of Kennebec along with 1 row of Red Bliss potatoes and they would get huge. I used my garden tractor for making furrows and then I would broadcast fertilizer in the furrows.
I would drag a chain through each furrow to mix the fertilizer with the soil. When the potato vines were up I would sidedress them and again when they started to bloom. I wasn't bothered with potato bugs this year. I don't raise that many potatoes anymore. We had very little rain this summer in MD and the potato crop was better than expected. Hal
