Allis 185 how big of a brushhog can it power?
Allis chalmers
09-30-2007 22:42:01
I was wondering how big of a brushhog a 185 allis can power. Someone told me a 15 foot batwing. I think a 10 foot efficently not much bigger though. Looking to get into the business and need your advice. Thank you in advance
georgeky
10-01-2007 07:41:43
 Re: Allis 185 how big of a brushhog can it power? in reply to Allis chalmers 6, 09-30-2007 22:42:01
third party image
See.
georgeky
10-01-2007 07:22:48
That tractor will handle 15 footer anywhere. 15 foot is easier to pull than a 10 footer. I know I have one of each. The 15 footer has more momentumonce it is turning and requires less power from the tractor. Kinda like the flywheel on a baler. Many farmers here pull them behind 50 HP tractors. They mow bushes, hills and anything anyone else mows. Farmall M will handle a 15 footer.
IaGary
10-01-2007 04:37:57
All depends on how your gonna use it.
If your just clipping pastures go for the 15'.
I pull mine with a IH 560 and get along fine.
If your going into 5' tall weeds that are thick, a 7 footer will be a load.
Gary
Briar Creek Stables
10-01-2007 03:31:30
Allis Chalmers 185 General tractor information: Manufacturer: Allis Chalmers Model: 185 Type: Farm/Agricultural tractor Model: 185 Years produced: 1970 - 1981 Total built: Factory: Original price: $18,891 Tractor power: Drawbar (rated): 65.0 hp [48.5 kW] Drawbar (max): 63.8 hp [47.6 kW] PTO (max): 74.9 hp [55.9 kW] PTO (rated): 74.87 hp [55.8 kW] Engine: Manufacturer: Allis-Chalmers Fuel: diesel Cylinders: 6 Bore/Stroke: 3.875x4.25 inches [98 x 108 mm] Displacement: 301 ci [4.9 L] Compression: 16.25:1 Rated RPMs: 2200 Cooling: liquid Torque: Firing order: 1-5-3-6-2-4 Oil capacity: 11 qts [10.4 L] Transmission: Type: constant mesh Forward: 8 Reverse: 2 Transmission: Type: Forward: 4 Reverse: 1 Going on this info. I would say a 10ft would be the way to go. I don't believe this is enough HP to run a batwing mower. It may actually run the mower, but you would be asking alot out of a tractor that's under 100 hp
I'm sure there's others that will disagree with me. This is just my opinion.. I would stay with the 10 ft.
