allis No. 80 series "c" cultivator
S2mcgowan
10-01-2007 10:32:46
I'm looking for a copy of the No. 80 cultivator manual for an Allis "C". Does anyone have any pictures of a cultivator installed on a "C".
spencer mcgowan
10-02-2007 05:25:29
 Re: allis No. 80 series in reply to S2mcgowan, 10-01-2007 10:32:46
I believe I have everything but the pipes that go from the rear lift to the front gangs. I'll have to find a set of those or dimensions to make them.
JMS/MN
10-01-2007 23:22:27
 Re: allis No. 80 series c cultivator in reply to S2mcgowan, 10-01-2007 10:32:46
No pix or manual, but the front sections mount on a square bar that bolts to the front of the tractor, below and behind the radiator. Has a bolt (1/2 inch?) on each end to hold the left and right gangs, rear part of the gang bolts to the side of the tractor. Rear lift assembly mounts behind the fenders, with hyd cyl to operate it. Four pipes go forward to the four gangs mounted on the front. Rear gangs pivot on pipe brackets on the rear of each rear axle, plus hooked to the rear lift assembly.
J.C.in AZ.
10-01-2007 16:36:13
Page 79 of the Book: Allis-Chalmers Tractors : A Motor Books International Publication,published in 1992, Titled [Farm Tractor Color History] with Text by C.H. Wendel,shows a very nicely restored AC "C" with a Mounted Two Row Cultivator owned by Ivan Henderson and at that time he still used it for Cultivation,sadly that was 15 years ago. Who knows the current status of the "C" or Mr. Henderson either for that matter ? .If I knew how to post a Picture here I could post it for you,but .
