JD Bush Hog Mower
jtwat
10-24-2007 14:08:58
The blade carrier keeps comming loose from the gearbox output shaft.
I removed it and the splines on the carrier are worn down. The splines on the gearbox output shaft are fine.
Is there anywhere i can get a replacement carrier or the 12 spline sleeve?
I can build a new one if I had the splined sleeve.
