Has anyone ever....
Fm
04-08-2000 19:58:46
bought a three point for a 77 Oliver from Worksaver? The one with two cylinders, Model #HK-16782? What did you think, how much did it cost, and is it good? How about a blade, the UB series? Thanks in advance.
MrG
04-10-2000 14:55:28
 Re: Has anyone ever.... in reply to Fm, 04-08-2000 19:58:46
I bought a Saginaw for my 560 with 2 cylinders, however I only use one (it will operate with either or both)...unless you are planning on lifting 1/2 ton or bigger round bales, save $100 and just get a single cylinder, it will adequatley handle a blade, bushhog, small chisel, etc. Gadget
Mongo
04-08-2000 22:03:56
FM, I bought a slightly used one a few years back. I got it with the cylinders and lines, cat II. I gave $500 for it. It will easily lift the whole tractor if so inclined. Mine has the two way cylinders and a place to put two cat II pins to give you down pressure. That came in handy when putting in 1/2mi of fence.
