Implement Identity, Z part #s
Amatt
11-19-2007 05:26:28
I found a category 1 3-pt 5 shank chisel plow with two concave disc coulters, mounted rigidly, 4 inches apart per shank. There is no manufacturer's tag, but all the visible part numbers start with the letter "Z". I wondered if the "Z" was a giveaway to the make and if anyone knew what that might be?
IBorange in TX
11-19-2007 21:57:39
 Re: Implement Identity, Z part #s in reply to Amatt, 11-19-2007 05:26:28
Some of the parts from the horse drawn area had the letter Z with the numbers. ex, Deere used a number set as Z130, but Dain used the Z also. The Dain part numbers usually ended with the letter E, ex Z65E. Just some notes that I have kept on the old parts numbers. I don't have a book on the numbers, just some personal notes. When I find an old part, I write the number down and the brand of equipment. HTH
Good luck
IaGary
11-19-2007 05:40:45
What color is it?
Gary
Amatt
11-19-2007 13:03:01
 Re: Implement Identity, Z part #s in reply to IaGary, 11-19-2007 05:40:45
Rusty. A little paint is visible on the coulter bearings that may have been black and some white-looking paint is visible on another part. These colors are badly faded. Another detail about the machine is that the shanks are not adjustable from side to side, but have three depth adjustment holes.
