John Deere Implement Trailors
7812
01-14-2008 03:47:24
John Deere made an implement trailor I believe the number is 201, also Donahue made the same type of trailor. I was wondering what the axles were rated at as far as tons. The one I'm looking at has 5 bolt rims.
James22
01-16-2008 07:40:08
 Re: John Deere Implement Trailors in reply to 7812, 01-14-2008 03:47:24
Dug the JD model 201 operators manual out, and it gives a 7850 lbs bed capacity with a carrier weight of 2825 lbs. Their math isn't too good because they add the two together, and come up with a gross weight capacity of 10700 lbs.
flying belgian
01-14-2008 14:27:47
I have the Donahue brand which is the same as JD. 28 ft. long rated for 6000 lbs. No you cannot have brakes as you pull it about 12 ft off the axles to lower it to the ground. So you would need brake lines that stretch and contract 12 ft.
7812
01-14-2008 10:19:47
I wanted to haul small squares of hay on it and wondered what it would hold without overloading it too much. Of course none of us on here would ever overload a trailor!!!!! !!!
tim[in]
01-14-2008 09:53:17
I've wondered about using one of these on the road instead of a more expensive trailer for buying the occassional piece of equipment at auctions,etc.I wonder can they have brakes added on?
James22
01-14-2008 06:30:40
I've got a JD 201 with 5 lug rims. I believe the rated capacity is 8600 lbs. If necessary, I could get the operators manual and check.
RickL
01-14-2008 05:13:14
I have 10 of those units in my haying business. Memory serves me right they are around 12000 lbs. I have spec sheets in the shop office can look later if your really need info
Tx Jim
01-14-2008 03:56:23
 Re: John Deere Implement Trailors in reply to georgeky, 01-14-2008 03:47:24
Don't know the rating but I think Donahue built that trailer for JD. Tx Jim
