NH 315 baler
Al Kale
02-06-2008 13:59:00
when the knotter hub rotates it seems to hang when it hits the clutch pawl roller. any ideas
Thanks
al
smirkey
02-07-2008 07:06:03
 Re: NH 315 baler in reply to Al Kale, 02-06-2008 13:59:00
try jerking back on the needle drag link on the other side (right side), this should put the clutch paw firmly against the stop of the clutch. if that stops the jerking of the chain, maybe the brake is too tight on the knotter stack. or possibly the brake is too loose or worn out and allows the knotter to bounce back. anyway. thats a start.
Tx Jim
02-07-2008 04:10:56
 Re: NH 315 baler in reply to Hugh MacKay, 02-06-2008 13:59:00
Al is a needle hitting anything while knotter shaft is turning? Jim
kossuth
02-07-2008 04:01:51
 Re: NH 315 baler in reply to Briar Creek Stables, 02-06-2008 13:59:00
Al Kale said: (quoted from post at 04:42:24 02/07/08) roller turns free and everything is well greesed,keep comming up with ideas no worn spots on the roller, this is the part that is inside the housing on the left side of the knotter
thanks
al
Almost sounds like the roller has a flat spot or something is bound up in there. It's almost always an easy fix, it's just finding it that's the bear sometimes.
KEH
02-06-2008 15:46:18
Is clutch pawl roller stuck or does it turn freely? Is the knotter assembly well greased? If roller is stuck has it worn a rough spot on the cam? It's been a while since I worked of a NH knotter so I'm just tossing out ideas.
KEH
Al Kale
02-07-2008 03:42:24
 Re: NH 315 baler in reply to KEH, 02-06-2008 15:46:18
thanks
al
