Loader hydraulic fluid
Adam IA
02-07-2008 21:29:05
I have an unknown make/model of loader and one of the cylinders is leaking. I need to keep using the loader through the winter and just want to top it off. Problem is I don't know what type of fluid to use, or how high to fill it. I went to buy fluid but it appears to be brand specific. The inside of the loader support is the tank. I can not see the fluid it is so low in the tank. I am guessing the tank would hold several gallons. The leaking fluid is red and looks like tranny fluid. The loader is powered by a hydraulic pump on the front of the tractor. Tractor is a Ferguson F40, but loader is probably from the late 70's I would guess.-Loader has homemade mounts and is yellow. Any help would be appreciated. Thanks.
randallinMo
02-08-2008 08:05:56
 Re: Loader hydraulic fluid in reply to Adam IA, 02-07-2008 21:29:05
To be on the safe side I would drain all the existing fluid and then fill with any recommended Hydraulic fluid. Thenceforth you simply add the same.
BCnT
02-07-2008 23:35:57
a simple way to determine how to fill it is leave a few inches under fill hole for expansion and loader cylinders retracted to shortest length...i seriously doubt a simple hydraulic system like that couldnt use hy-tran or similar fluid...just dont mix types.
paul
02-07-2008 22:06:41
My combine uses tranny fluid for the hydraulics. That would not be unheard of.
--->Paul
El Toro
02-08-2008 11:30:26
 Re: Loader hydraulic fluid in reply to paul, 02-07-2008 22:06:41
My garden tractor with hydraulic lift and hydrostatic drive uses Dexron ATF. I've had it 37 years. Hal
