New Holland 290 Square Baler
skyharborcowboy
02-10-2008 05:45:42
What is everyones opinion on this baler? Are they easy to work on, reliable, get parts for? What are they worth? What size bales do they make?
Thanks,
Joe
skyharborcowboy
02-11-2008 21:35:02
 Re: New Holland 290 Square Baler in reply to skyharborcowboy, 02-10-2008 05:45:42
Why do some balers have engines on them? Is it just because the tractor they were used on didnt have PTO's? Can a baler that had an engine on it be converted over to PTO driven?
Thanks,
Joe
Clefus
02-11-2008 19:13:46
jeez 100 lb bales.....ouch...
I still use a super 66....but dont feed an entire feedlot....
BobHnwOh
02-10-2008 15:37:57
Joe,I have a NH 268 and it is a great baler,NH is one of the best small square balers made!
skyharborcowboy
02-10-2008 07:13:12
That is what I figured when someone wants to give you one.
Joe
jeff outwest
02-10-2008 07:06:44
Joe,
Find yourself a Freeman 330 or 370. 290 New Hollands are slow junkers that parts hard to find for. I think almost impossible. An outfit up here still runs 2 of them and they have about 12 for parts in their boneyard. They also make a 17" X 23" bale. Can't make a nice 100 pounder with em. Have make 125 or your can't handle them. Freeman's have parts you buy at NAPA or make with a torch yourself. That's how them girls where made till they sold out to Allied a fews years back. Only thing modern at the Freeman's factory was the torch for cutting our cams for the pick ups. We custom hay and run to 80's vintage balers with the plunger shimmed and keep up with the Hesston boys and New Hollands.
BC in TN
02-11-2008 14:01:49
 Re: New Holland 290 Square Baler in reply to jeff outwest, 02-10-2008 07:06:44
Jeff:
Are you talking about New Holland hay balers?
Last I checked you can still buy parts for most of "em - say, at least for the ones that are no older than 65 or 70 years old. I use the great-grandfather of the 290, a NH 68 - just rebuilt it a couple of years ago - most internal parts still available from the NH dealer. Most people I know who really work hay and feed it don"t really make nice 100 lb bales - I guess things are different outwest.
ric1
02-11-2008 16:22:53
 Re: New Holland 290 Square Baler in reply to BC in TN, 02-11-2008 14:01:49
i sure wouldnt wanta go throwing around 100 lb bales my back hurts just thinkin about that
Gerald in TN
02-12-2008 06:07:10
 Re: New Holland 290 Square Baler in reply to ric1, 02-11-2008 16:22:53
You can still get parts in my area for all different types of NH square balers, even back to the NH 68 model. I have used them all my life and they are very dependable. Many times I have baled over 1,000 bales without missing a single bale, so don't listen to anyone who says they are not reliable or dependable. By the way, if your hay is dry it will make a good tight bale weighing 50-60 lbs, you won't kill yourself loading and unloading them.
